Question about Jenn-Air JGC8430 Gas Cooktop
Jenn-air gas cooktop. main ingition went out,
Jenn-air gas cooktop. main ingition went out, replace with new one, with new base and ing factory mounted. Now when you plug the power cord in all 4 start clicking, start up the gas on the new rt front any everything works fine. When tr front is turned off, all 4 burnners start sparking, will not go off until gas on main burner is turned back on, or power plug is disconnected. Everything is dry and new ingn installes exactly as orginal.
  • 1 more comment
  • town1217 May 22, 2011
    I replaced the whole burner asy with the factory cermaic spark, part # 74007735, the old burner asy had a corded screw which held the cermaic spark, so I ordered the whole asy, burner and cermaic spark.
    When I plug the 110 vt in all 4 of the top burners start sparking, when I turn the gas on the one I replaced all works fine, the other 3 stop sparking, but when I turn off the gas, they all start sparking. So I am getting spark to all burners, I not sure what to do from here.
  • town1217 May 23, 2011
    I replaced the main burner asy and the electrode with a factory replacement.
    As you said I waited till the next morning ,pluged the unit in and everything worked fine. So something was wet.
    I am not sure what switch u are refering too, that gets wet and needs drying out. Is it the gas on control switch or is there another switch near the burner?
    thanks
    ct
    yes
  • Jenn-Air Master
  • 43,501 Answers
The switch in that main burner is bad and is causing the ignition to stay on....you will also have to replace that one burner switch.
800x600
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on May 23, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 23, 2011
    The switch is actually behind the burner knob ...but you should be ok now....
  • Jenn-Air Master
  • 1,902 Answers
Hello & Welcome to FixYa
The problem seems to be with the spark module, don't know what you mean by ignition system. Please check this parts image and tell me the part# that you have already replaced, if you have already replaced the spark module then it means the pressure regulator needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 22, 2011
  • Kevin White
    Kevin White May 23, 2011
    Check the ignition switches on them, if they are fine then the spark module needs replacement
How to remove the top panel of the cooktop?
To remove the top so that you can replace the electrodes, you just need to pull all the burner grates off and knobs. Then remove all the burner caps and rings off so that all you're left with is the cooktop and the burner bases. There are screws going into each burner base. Remove all the screws and the burner bases will pull up and off and then you can pull the top of the cooktop up and off.
Feb 13, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
One of the ignitor is cracked. Do I need to replace the whole burner base?
you do not need to replace the whole burner base you need to replace de ignitor
Sep 24, 2011 | Jenn-Air JGC8536 Gas Cooktop
The electric sparker for gas cooktop will not go off, sparks as long as the electricity is plugged in
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter
Jan 25, 2011 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Gas ignighters continue to spark after gas is ignighted.
Jan 11, 2011 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jenn-Air gas Cooktop fire is low
www.servicematters.com/maytag_library/docs/16010492.pdf service and troubleshooting manual above.
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
I have a Jenn Air gas cooktop, only about 2 years
If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
Jan 03, 2010 | Jenn-Air Cooktops
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
JENN AIRE CVGX2423 COOK TOP
short in the fan wirring.. it is not easiy fix . you need to replace the fan and short wieeing.
Dec 19, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGC8430 Gas Cooktop Logo
106 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
