Question about Samsung Refrigerators
Ref: samsung RB215LABP refrig. Glass shelves have a plastic edge that serve as the supports for the shelf. When something spills on a shelf like blood from a steak or milk, it gets under the plastic that wraps around the glass shelves. Is there any way to get the glass out of the plastic piece so it can be cleaned? thanks. ed
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
arikrom
  • 528 Answers
SOURCE: red wine spilled on bottom glass shelf (sitting on
it must be removable , if it break one day it have to be replace so try harder it must come out somehow
Posted on Jan 01, 2010
SOURCE: maytag refrigerators mtbe1956de
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Posted on Jan 13, 2010
Testimonial: "Gee... you are really smart! When id doubt brute force is good."
aasc
  • 1606 Answers
SOURCE: I get puddles of water
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Aug 16, 2010
SOURCE: how to remove take glass shelf to clean trapped spills
lift the front nosing by prying with your fingernails up...it will roll in place allowing you to remove the glass
Posted on Dec 04, 2010
New home with wine frig but I want to turn it into a beverage frig. Where can I buy glass shelves to replace the wine racks in my U-line?
there must be a glazier business in the town to repair windows etc so go there with the length and width measurements and the thickness should be no less than 1/4 " or 6 mm to carry the shelf load
as the shop for a recommended glass thickness but I would not go under 6 mm and make sure that the edges are sander to get rid of sharp edges
Nov 18, 2015 | U-Line Refrigerators
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
Can you remove the glass shelf above the 2 vegetable boxes in a RFG23UERS.
It's probably removable. Drawer below needs to be unloaded and removed. you probably can push the glass up from below. Otherwise pleas consult your owner's manual.
Mar 08, 2015 | Samsung Refrigerators
Refrigerator glass shelf shattered
you purchase the new shelf from the manufacturer, the glas they use in shelves is specialised, be careful.
Nov 16, 2013 | Refrigerators
How do i adjust the shelves in my Maytag side-by-side refrigerator?
You should have pins or clips that rest in a standard that you can take out for adjustments. Simply pop them out . If yours are made onto the shelf itself, then raise up on the front side of the glass then pull it out from the post or standard.
Feb 09, 2013 | Maytag 25.1 cu. ft. Side by Side...
Wher can i get parts for my liebherr premium ctnes 4753 nofrost
try using frosted glass(toughened)more permanent,use a plastic shelf as a template.....
Jul 30, 2010 | Liebherr KDPes 3142 Premium
Samsung Cooltech spare shelves available in b'lore??
it is possibly cheaper to go to a glass firm and get glass cut and edges polished to fit than it would be to buy replacement shelves.the mark up is horrendous on any spare parts......
Apr 20, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
24 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
