Question about Shimano Ultegra Triple Front Derailleur Fd 6603
Activated flip switch of front derailleur a bit hastily and chain went over the granny wheel - no big deal, has happened very occasionally and chain was reset gently. BUT the mechanism is jammed at the top! The flip switch had not gone back to its original position and remains 2-3 mm toward the right. It is loose but wont engage derailleur so I'm stuck in granny wheel. The derailleur cable is not broken and not too tight. Releasing the tension completely with pressure on derailleur does not help. The mechanism is jammed at the top! Thanks for any helpful suggestion about what to do! G. Miescher, Berne Switzerland
    Brigadier General:
  • 8,546 Answers
First, look carefully at the front derailleur mount and evaluate if it has cracked, bent or loosened. There is no condition where it should ever contact the chainrings. Then loosen it and free it from the jammed condition. You may have to also losen the shifter cable, reinstall the derailleur with proper clearance and adjust...
http://bicycletutor.com/adjust-front-derailer/
or...
http://www.parktool.com/blog/repair-help/front-derailleur-adjustments
Posted on May 22, 2011
I have Campy mirage 10 sp and the rear deraileur shifter ( the right shifter) will skip gears while shifting down 23 to 11. Often I can hear the mechanism making multiple "clicks" on a single...
I would lube everything and check the derailleur adjustments and cable tension. Some Campy chains are 'notchy/clunky' all the time. It's just the way they are. If the bike is low mileage most likely nothing major is wrong. Check the derailleur hanger too just in case you dropped the bike and bent it or something. The shifter 'G' springs will wear out before the derailleur. When the springs are worn, the shifts will be imprecise and will jump from gear to gear without shifting. One thing with Campy stuff...it DOES take awhile to break in. Unless the shifting is horribly off, I wouldn't worry about it - just ride it more - and see what happens. Mirage is a good product, I think inline with Shimano 105 stuff.
Sep 12, 2011 | Campagnolo Mirage
Cmapy Veloce 2010: Down shifting front derailleur fro big ring to small, chain free wheels not fully engaging small ring. When riding with big chain ring clicking clacking noise.
Both of these issues sound like your front derailleur needs adjustment. I would highly recommend you take into your local bike shop and have them fix it for you. This could be as easy as cable tension or limit screws not being set properly, or could be something is broken and needs replacing.
Mar 25, 2011 | Campagnolo Cycling
How to adjust front derallier on fuji 18 speed
You will need to raise the back wheel to perform these adjustments... so that you can activate the pedals and oberve closely the functioning, as you adjust....
On the tube mounting: The derailleur needs to just clear the teeth of the front chain wheels, as it moves from one to the other. It needs to be square with the chain wheels.
The other adjustments are limiting in nature. You need the derailleur to not move the chain off of the outside of either front chain wheel. as you get closer, move the rear derailleur to extremes and then shift the front derailleur, slow and fast..... Limit is correct when you can move the derailleur so as to not ride on the chain, but not throw the chain off the wheels.
Sometimes, guys turn the front derailleur, slightly so that the last portion of the derailleur body gives the chain a little boost to the bigger gear...This is just a very small amount. Sometimes it just works better that way.
Nov 22, 2010 | Shimano 24 Speed Road Racing Bike Bicycle...
I have shimano rd6500 rear derailleurs. when chain is on small chain-ring and smaller rear sprockets the derailleur cage is rubbing against the chain.How do i tension chain to hold cage away from chain,...
If you learn to shift correctly this won't happen..
Google bicycle shifting technique, for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible. Excess sideways stress on the chain will wear it out prematurely and increase its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you're having a problem with. Get behind the bike and look staright along the top of the chain. As you can see the line of the chain is a mild zig-zag where it is parallel to the bike at each gear but needs to angle across the drivetrain in between. On some bikes the chain might even come in contact with the next larger chainring when used this way.
If you can shift to the big-big combination without snapping the rear derailleur off, you're lucky. The big-big combo uses up all available chain length and the rear derailleur will be pulled toward the front of the bike, sometimes so far that it is in danger of being snapped off.
THERE IS NO UPSIDE TO CROSS-CHAINING.
As you can see, the rear derailleur is not long enough to **** up all the slack this gear combination creates. There are other combinations that would yield the equivalent gear ratio without either stressing the drivetrain or dropping the chain.
The basics of shifting are these:
1) The big ring and right side of the cassette in back are for speed.
2) The small ring and the left side of the cassette are for high torque, lower speed
Feb 24, 2010 | Shimano 105 Triple Braze On Front...
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
Throwing chain too far on an upshift up and off
The "H" screw is the one that is letting your chain jump of f of the ring. If the screws are not labeled, the way to distinguish the two is to shift the front as high as it can go and hold it there manually. Screw either adjusting screw in. If you are screwing the correct one, it either will not move at all or move only very slightly.
First thing is first: flip your bike over onto the bars and saddle. The best method to adjust these settings is to shift into your small ring and let loose the shifter cable. Now shift your rear derailleur into the lowest gear and manually pedal the bike while adjusting the "L" screw on the front until the derailleur cage allows relatively free rotation of the chain. Now set the barrel adjuster on your down tube fully turned in (clockwise). Pull the cable taut and reattach at the derailleur. Shift into your middle ring (or high ring if you have a double-ring crank) and then shift the rear to the highest gear. Use the barrel adjuster to get the derailleur cage to just clear the chain while cranking. If you have already succesfully set your "H" screw to a point where the chain no longer jumps off, then you are all set here. If not, hold the front shifter in while cranking and set the stop so the chain cannot get off of the big ring, but far enough out so you can purposely over-shift by just a bit. Sometimes if you shift early, that little bit of over-shift is very helpful.
i hope this helped, but if you would like to see pictures of this happening, go to parktool.com/repair and check out their tips on derailleur adjustment.
matthew
Oct 22, 2009 | Campagnolo Record Front Derailleur
Installed new front sram x9 trigger shifter & its overshifting
You might have to consider changing your bottom bracket for one with a longer shaft. Examine your chain line and do some research here:http://www.parktool.com/ and also here:http://sheldonbrown.com/gearing/index.html
Oct 15, 2009 | Cycling
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 02, 2009 | Cycling
Front chain drops into lower gear without engaging and does not stay tight when coasting. it sags down.
It sounds like you'll need to readjust the gearing cable for the front gear guide and you'll probably need a new rear derailleur as it sounds like the spring for the derailleur is no longer applying tension on the chain
Aug 07, 2009 | Cycling
On my bike with shimano ultegra shifters and 105 front deraileur, I can't shift onto the big chainring. The deraileur is not at the stop, but I can't move it any farther. How do I fix that.
Try this first:
Shift into the little ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your down tube. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Jun 23, 2009 | Shimano 105 Triple Braze On Front...
Shimano Ultegra Triple Front Derailleur Fd 6603 Logo
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
