Question about Breadman TR2200C Ultimate Bread Maker
Hi: I use the Breadman TR2200C breadmaker. Right now I have two machines--a "good" one and a more worn-out backup. I would like to create a complex dough-rising cycle using "Personal Recipes." The programming options allow some changes in timing to the preset cycles, but a bread cycle will not allow you to delete baking, and the dough cycle does not allow you to add Rise 2 and Rise 3. Theoretically, Personal Recipes should allow me to do this. However, the instructions for creating a personal recipe (p. 24 in my manual) say to activate the function by pressing the PROGRAM button for 1 second. This does nothing but start the program alteration function in whatever cycle I am in. I can't get to "personal recipes." Has anyone else been able to activate this function? Any ideas? I have been using the Breadman for 10+ years, a loaf or more a week. I've managed to get a lot of mileage out of these machines. But, still no luck with this one function. Thanks for any thoughts on the subject.
  • sand_qween May 23, 2011
    Yes, I have tried pressing the button for a longer period of time--up to 30 seconds. The problem with this machine (both of the ones I own, actually) is that the button is not really that sensitive. You really have to jam it and sort of roll your finger to get it to acknowledge a command. I am not convinced it can tell the difference between one second or ten. It seems more binary, as in, "pressed" or "not pressed" with no shades of gray such as "pressed for a period of time."
  • 496 Answers
I'm going to be very truthful with in in the fact that i have not used the breed maker you are using so i'l really not sure how to do what you need. I am how every including the number and e-mail to breedman. i would have called to insure that the number i am giving is going to help you. but it's after there work hours.
Phone Number: 800-231-9786
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Email: customerservice@breadman.com
I hope this helps you i have watched you post and see that no one has been of any help so maybe this will get you closer to your answer
best of luck
M.Woodring
Posted on May 28, 2011
  • 683 Answers
Try to press and hold the program button for 2 to 5 seconds.
Posted on May 23, 2011
NY Breadman Ultimate TR2200C stopped working. The "gear shaft" on the bottom of the machine no longer turns. Any suggestions?
Hi, Take the pan and paddle out of the machine and see if you can turn the paddle freely by hand. If no, then the sealed bearing has failed and you will probably need a new bread pan. If it turns freely then it could be the belt is loose or has fallen off. Belts and motor are located in base of the machine. Unplug machine before working on this part. Hank
Oct 31, 2010 | Breadman TR2200C Ultimate Bread Maker
Leaky Bucket
The sealed bearing can not be replaced. You will need a new bread pan. Hank
May 31, 2010 | Breadman TR2200C Ultimate Bread Maker
My Breadman TR555LC is leaking. I can see that the seal is worn out on the bottom. Is there anywhere I can find a new breadpan?
Your best bet would be to look on eBay. Perhaps you can get one there, but they are kinda expensive if you can find one. Hank
Feb 17, 2010 | Breadman TR2200C Ultimate Bread Maker
My Breadman bread maker is broken. The pan jumps
It is likely that, due to a poor design the contact between the paddle traction and the machine is worn out.. Check it and you will see that the bare metal is shiny there in the two bumps in the rotating plate in the machine.
I used a dremel-like rotary tool to grind the contacting part so that the contact between the machine and the paddle traction is orthogonal.
Worked fine for me.
Regards
Nov 16, 2009 | Breadman TR2200C Ultimate Bread Maker
Breadman tr2500bc pan popping out
I read in a review that the pan can warp if you read instructions because it said to fist run the machine in quick bread mode to clear factory coating. Review said to run in quick bread mode with lid open so it doesn't overheat, heat warps the pan, so it pops out . However manuel never mentions to leave lid open. I just got one and hope they are right. I just ran it new no ingredients quick bread lid open...
Nov 15, 2008 | Breadman TR2200C Ultimate Bread Maker
Where can I find a replacement breadpan for the breadman tr2200c?
I found the part at
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
http://www.saltoninc.com/
Nov 13, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman Ultimate TR2200C: "--H Error"
I had the same problem recently, however my machine was in use. I unplugged the breadmaker, let it sit and cool. After 1/2 an hour, It was functioning properly. If this doesn't solve the problem, after plugging IN try holding STOP/RESET button for 3-4 seconds.
worth trying...
Oct 20, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman Ultimate ¨HI¨ Error
If there was a power outage one of the internal circuits could be messed up giving you this error. You may want to contact the maker and arrange for repair service or diagnostics in house.
Nov 26, 2007 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
