Question about LG WM-1485FHD Front Load Washer
Cant rurn on my my washing machine
I have an lg front load washing machine, but i keep pressing the on button but it still wont come on. how do i open up the front panel?
  • rdbathrooms Aug 15, 2008
    hi i have just fixed the problem, i took it all apart. the problem was that the on button was'nt aligined properly to the motherboard. so when i was pressing on the chip was being pressed inside.
    thanks
  • 876 Answers
Have you tried a simple reset, by unplugging, waiting several minutes and then replugging it in? Is it plugged into a gfi outlet? is the little red button pushed in? It should be. It hasn't flipped a breaker off has it?
Posted on Aug 15, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 15, 2008
    Well, there you go! Good for YOU and saved yourself a service call . Thanks for using Fix YA
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
The code cl keeps coming up and the washer will not shut off
CL is child lock. Press and hold the child lock button(maybe a key icon) for three seconds to unlock
Mar 23, 2015 | LG WM2455 Front Load Washer
LG WASHER LE CODE
Fix for Error Code "LE" on LG Front Load Washing Machine
I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
1. Press the Power button
2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
3. Press the power button and run the machine normally.
Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
May 30, 2014 | LG WM-2277HW Front Load Washer
Washer won't start - sometimes
Jason, take a look at this link and follow the steps very carefully. Were insulated golves. How to Fix an LG Front load washer machine that wont spin
Feb 28, 2014 | Frigidaire Washing Machines
How do i open my machine?. wash is done but the machine just wont open ???
The usual ways for most front load machines are to try reset of the cycle(using normal reset buttons), completely unplug the machine for 5 min and try again or to turn off machine then press and hold on/off button for 10 sec. Unfortunately this is most often due to a faulty door lock and you will need to have it replaced.
Jul 08, 2013 | Tricity Bendix AW1260W Front Load Washer
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
Washing machine - LG TROMM - door is not opening
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............I'll be back with a further post
Mar 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front load washer
LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
Oct 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
Lg tromm wm2277wh washing machine
Is the water valve screens plugged restricting the amount of water going into the washer other wise your pressure switch is reading the wrong water level.
Oct 13, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-1485FHD Front Load Washer Logo
376 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
