Question about Hayward Super Pump 1 1/2 - Hp for In Ground Pools
We just turned on pump, was on for about 30 seconds, hummed, did not come on and pump got hot. any suggestions
  • 4,340 Answers
This sounds like a frozen (seized) machine. Is the impeller able to turn? If the impeller is locked, maybe you can release it. If not, you may need to haul the unit to an electric motor shop, for repair. Some more powerful motors use a start up system, some mechanical, some use condencers (sometimes called starters), and at that point, you want to be SURE what is needed, for safety.
Hope this helps.
Posted on May 22, 2011
My Gould pump has been working fine for 2 months now has stopped pumping. Now when you turn it on it hums for 30 seconds and then kicks off. It has water in it so don't know what the problem is.
pump impeller jammed ,motor bearings seized,motor seized ,short in pump windings if 208 possible lost a line feed --need to check power and pump to see if turns
May 30, 2017 | Cars & Trucks
Fisher&paykel ,smart drive excellence 7 .5 ,the washing machine stopped working during the pumping out of the water.no power on the top panel and a slight humming noise
What is it? No power to panel or slight humming sound which indicated there is power? Can't be both. I would suggest that the humming sound if you put it on spin, will be the drain pump trying to go. If pump is left humming like that it will get hot & shut the power off until it cools down again. Pump hums when it has a blockage & can'y spin. Clear the blockage.
Dec 29, 2016 | Fisher and Paykel Washing Machines
When I start my truck there is a humming noise for about 30 second then it stops what could this be
If on start up then humming noise could be from any moving part like Alternator, any pulley or even the power steering pump, then goes away as the bearing gets hot and expands.
Mar 16, 2016 | 1999 Chevrolet S-10 Pickup
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Ran out of gas but I have put half of tank in now and my 98 ford explored 4.0 6 cylinder won't start does anybody have any suggestions? Plz help...
The fuel pump may have gotten hot and stuck. Try hitting the gas tank with a rubber hammer or a wooden bat with the key on. DON'T USE METAL ON METAL. You should hear it hum for 2-3 seconds if it's working. (have someone turn the key to the on position while you are near the tank) If you can hear the pump humming, and it still won't start you will need to change the fuel filter.
Feb 25, 2011 | 1998 Ford Explorer
My washer will turn on for 30 seconds to a minute and then no longer adds water then a humming continues but no water comes out
i would try to removed cabinet and check pump or coupling to the motor and pump and then check motor
May 02, 2010 | Kenmore 23822 Top Load Washer
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Ford focus 1.8 1999 engine turns over but won't start
you may not have enough fuel presur yet. try this -
turn key to on, listen for fuel pump noise (humming) for about 5 seconds. If no hum, you have a problem. If it hums, good. Now, turn key off for 30 seconds and turn key to "on" again. Repeat 5 times. Then try to start car.
The fel pump does run in "start" mode continually.
Jan 09, 2009 | 2000 Ford Focus
Hayward Super Pump 1 1/2 - Hp for In Ground Pools Logo
142 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
