Question about Miele M613G 800 Watts Convection / Microwave Oven
Miele Microwave Oven M 625 EG How can I replace teastlandhe light bulb? How is the protection plate fitted.
  • 833 Answers
SOURCE: panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: replace microwave light bulb
See page 24 of the owner's manual here:
Posted on Feb 08, 2009
  • 52 Answers
SOURCE: sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Posted on Feb 23, 2009
greenspan
  • 1734 Answers
SOURCE: Schematics for Miele Microwave M637-1EC Electronics
Ask them, they can get you many Miele schematics.
Posted on Jul 14, 2009
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
What do i do?m625 eg miele oven smoke from top and turntable ceased working
Impossible to say what the problem is but if the turntable has stopped you could check the turntable motor. This is easily accessed from the bottom of the unit but you have to actually break the sheet metal tabs that retain it in place and replace using the screws only.
May 14, 2014 | Miele M625EG Convection Microwave Oven
Miele H 4080 Microwave mica diffuser plate
http://www.amazon.com/Amico-Microwave-Repairing-Plates-Sheets/dp/B00880DAB0
Oct 19, 2013 | Miele M613GSS 800 Watts Convection /...
Miele M625 lightbulb replacement
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Often on a unit whose bulb is not meant to be replaced by the customer, the light is located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Dec 11, 2012 | Miele M625EG Convection Microwave Oven
The light in my microwave went out. how do i replace the light bulb?
Some have a plate on the interior of the oven that can be removed for easy bulb replacement but if yours does not you will have to remove the entire outer covering to access the bulb. If you have a combination microwave/Range vent you will have to remove the entire unit from the cabinet, then remove the outer cover, replace the bulb and re-install the combination unit.
Dec 13, 2011 | Microwave Ovens
I need to replace the interior bulb on my GE profile model jvm1850dm2vv microwave oven. Can I access it from the area where the replaceable filter is?
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
Jan 31, 2011 | GE Profile Over-the-Range Microwave
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
Panasonic bulb nn a753
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Replacing oven light bulb
On the bottom. Remove bottom plate you will see them (2). Don't forget to unplug it and metal parts can be very sharp, be careful.
Dec 09, 2007 | GE JVM1640 Microwave Oven
Miele M613G 800 Watts Convection / Microwave Oven Logo
121 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
k24674
Armin Buehlmann
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
