Need to replace lid switch and cant get the console to lift # 110.4720292 sears kenmore 24 " washer
    Sergeant:
    Champion:
  • 257 Answers
Watch this video
Posted on May 22, 2011
My kenmore washer won't drain or spin. I took out all the water & it still won't spin. I hear the lid "click" and I hear a "hum" when I turn the knob to spin, but nothing else...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 27, 2011 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Dec 03, 2010 | Washing Machines
I have a Kenmore 70 Series that is not draining the water or spinning. It is a top load. Model # 22722. Do you know what is wrong and can it be fixed? Cost to fix?
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts. You can find the complete model number (110.########) by lifting the lid.
A complete Lid Switch (See the diagram of the cabinet on the Sears site) is about $36.92.
Although I CANNOT recommend it, if cost is a real problem, you could likely leave the jumpers in place.
May 06, 2010 | Kenmore Washing Machines
Lid switch doesn't work
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
On most top loads, you can usually find the model number by lifting the lid and looking at the top of the tub. The model number may also be on the label with the serial number, part number etc.
If you find the model number, also go to the Sears site that has on line (PDF version) manuals.
SEARS ANSWER SITE
http://www.managemyhome.com/
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it works, the Lid Switch is a relatively inexpensive part.
May 03, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer, it washes but won't rinse or spin, I tried to lift the top off to check the lid switch becuse the lever pad is stuck down, but how do the tops lift off
Apr 18, 2010 | Kenmore 22622 Top Load Washer
I need to replace the lid switch on my kenmore washer. Does the top of the machine lift off so I can do this or do I have to take the whole thing apart? Is this something a novice can do? Thanks
The first thing I'd do is to verify that the switch is bad.
If it works, the Lid Switch is a relatively inexpensive part and easy to replace..
Jan 11, 2010 | Kenmore Washing Machines
How does one replace the lid switch?
Dec 13, 2009 | Kenmore Washing Machines
I HAVE A KENMORE WASHER MODEL 110.92284100 THAT
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92284100
Go to the section on the Sears site for the Top and Cabinet parts and you should see #11 Lid Switch.
See the following on how to gain access to the console and how to remove the cabinet
If you un-plug the washer and pop off the end caps, you should see a screw under each endcap.
Remove the screws and the console should tilt backward. Unplug the lid switch from the console.
Using a screwdriver, snap off the clips holding the cabinet on, tilt it forward and it should come.
You should have access to the lid switch with the cabinet off and the console tilted backward.
Oct 23, 2009 | Kenmore Washing Machines
How to replace the lid switch for a top load kenmore washing machine model 110.92480200 part#1170635?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92480200
Look at the top and cabinet section and you should see how the switch mounts.
A concern that I have is that the part number on the Sears site for your washer is
Switch, lid Number:3352630Substitution:285671which isn't the part number that you quote.
Oct 12, 2009 | Kenmore Washing Machines
Kenmore washer 24642300
The lid switch has failed. To replace lid switch;
REMOVE POWER, lift the console by removing the trim on either side. Grasp the top of the trim and pull forward to expose a screw. Remove both screws and lift console.
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The lid switch can now be accessed and replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
