Question about Crafts & Hobbies
Glue won't come out when heated up. The stick seems to have melted inside the gun. Now the insides are stuck together. I was using a 115V receptacle. Just read directions with gun, says to use a 120V receptacle. Could this be the problem
    Champion:
    New Friend:
  • 217 Answers
That may have been the problem. you can remove the glue with acetone (nail polish remover) if possible
Posted on Feb 26, 2013
  • 5 Answers
SOURCE: Glue gun support
put a towel over the glue and iron over the towl. the glue will melt and the towel will soak it up. That works for other things like crayons also.
Posted on Aug 27, 2008
SparkyNZ
  • 43 Answers
SOURCE: 3M EC Hot melt glue gun with modules has quit heating.
You'll have to look at the plug all the way to the heating element. It's possible it's melted, also it might be that the iron has poor contact with the wires attaching to it. Does it have any temperature control? Any thing that is in between the wires from the plug to the iron of glue gun might be shot.
Posted on May 16, 2009
Mrteaze
  • 101 Answers
SOURCE: glue stick is stuck in glue gun and can't be
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
Posted on Sep 29, 2009
slave2aslave
  • 302 Answers
SOURCE: I can' get the glue stick out of the glue gun
No need for concern. Just leave it there and then the next time you use it push a new one in as needed.
I haven't met a glue gun yet where you can take out the last remnants of glue stick.
If you prefer to remove it try this:
take a paper clip and straighten it (any thin,metal object will work) Heat the glue gun,unplug it,and then heat the end of the paper clip with a lighter/candle.
Insert it into the end that you load from,sticking it into the glue stick. Wait a short time and then pull the paper clip out. The glue stick should come out with it.
I find it easier to leave the glue stick in as I said,but it's your choice.
Posted on Oct 04, 2009
Milleniumboy
  • 106 Answers
SOURCE: master mechanic glue gun 207 stopped working
There is a glue build up inside. Most likely in the feeding mechanism, try to heat it up, the unplug, and use like a paper rolled up to try to remove some of the glue. :)
Posted on Apr 03, 2010
Testimonial: "I ended up removing the tip and heating it with a torch to clean it out."
Is there a seal between the nozzle and the tip? I have glue leaking out everywhere??
No, no seal. The heating element is just a heated tube with the nozzle simply threaded into its end. The heating element in your glue gun may be cracked. Or... possibly... you (or someone in your household) got it hot and laid it down and left it that way for a LONG time, and the melted glue backed up inside the heating element. A glue gun should never be laid on its side while hot but idle, especially for long periods of time.
Jul 31, 2014 | Stanley GR100 DualMelt Pro Glue Gun Kit
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
Wires detached stanley hot glue gun
Not sure about the wires, but you can contact Stanley customer support here:
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
also, check and see if the gun is still under warranty, you may be able to exchange it for a new one
Dec 24, 2012 | Stanley Bostich Heavy Duty Dual Melt Glue...
I bought a Surebonder Fine Tip Hot Glue gun (small, for crafting) about less than 2 months back. It was fine at first until it stopped squirting melted glue and i had to manually push the glue stick from...
My guess is that you left the gun plugged in too long for the amount of glue that you were using. If you are using it for a good squirt every minute or so, you can leave it plugged in, but if your leave it plugged in too long while using too little, then the heat works it's way back up toward the back of the glue stick. First thing that happens is the glue-advancing trigger stops working because the advancing mechanism can't push against the softened glue stick. Leave it run even longer and it melts further back. Then when you turn it off it cools, but the melted glue is now in places it shouldn't be. If you take it apart you might be able to scrape and pry all of the once-melted glue out of it, then you would be back in business. Good luck!
Aug 27, 2012 | Crafts & Hobbies
*Jammed Glue in Entry way* HELP!
You can try heating up the entry way of the glue gun where the glue is jammed using a lighter or a candle (keeping the flame at a close distance, but not touching the glue stick) until it melts enough to slide out the back.
Jun 20, 2012 | Barbara K ! BK24162 Mini Glue Gun?¡
I have a glue gun (brand = POWER CRAFT a german product stated) I forced the glue stick into the gun to use up what was left of it and now I cant get it out. Its completly stuck inside the gun. Is the...
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Dec 07, 2010 | Crafts & Hobbies
What is wood glue sticks
Wood glue sticks are hot glue sticks which are specifically designed for use with wood (such as for glueing together a birdhouse).
Sep 25, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
Crafts & Hobbies Logo
205 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
