I plug in the flash & my MAC computer computer does not see it...nor can I find it..but when removed...it says that device was not removed properly...please help....Thank You Jilli
  • 27,725 Answers
Im not sure about a mac computer but i no with windows you should remove the hardware safely device when removing any hardware if you finally get it back right click and see wahat options are there in windows the safely remove hardware is a small arrow on the bottom right of the screen
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
this is for windows im not sure about mac computers
hope this helps
Posted on May 22, 2011
Hp back files on card can my computer restore these
The Hx 4700 series and the & The Hx2190 have a removable card Compact Flash or SD Card, if the information you want was stored on these you can buy a USB Card reader from woolies plug the SD or Compact flash into the card reader and plug it into the USB port of your PC or mac and it will be readable (no drivers needed). You may also be interested to know that there are updated ROMS available for this model to update the OS & the Office Apps + increase the max capacity of the storage cards that are recognized.
Mar 29, 2014 | HP iPAQ HX4700 Pocket PC
Erasing old music & loading more
While the device is still plugged into your computer, empty your trash. That should delete the music off the device as well.
Mar 02, 2014 | Finis Swi MP3 Player
Problem: Rosetta Stone msg: 1117 error occurred in the speech component operating system: Mac OSX Hi, I Have Rosseta Stone installed on my macbook pro (osx) and have/used it over a week now....
Try my steps:-
1.If you know removing installed programs from MAC, then please remove this application named-Rosetta Stone.
2. Now, remove all the cables & wires if your hardware audio device & turn off your computer.
3. Reconnect all the cables & wires & start your computer.
4. This time, reinstall the audio driver.
If this doesn't work, then you may try these ones:-
METHOD 1: Perform Step 1 to 3 again & install a different audio driver instead of Rosetta Stone.
METHOD 2: (This is only if METHOD 1 is also not working) Try your mic in any other MAC by installing Rosetta Stone in that system.
Note: You may search for a different audio driver at http://www.download.cnet.com/. Here search in mac column.
For any more support or any questions in future, you are the most welcome to contact me at abmakm@yahoo.com.
Feb 21, 2011 | Rosetta Stone Spanish (Latin American) -...
Locks frequently and restarts sometimes all by itself. Parts of the screen regularly skews in triangular shapes.
  • Verify that the power outlet you're using is good and your power cable is firmly connected to the wall outlet-if using a surge protector, be sure that it's firmly plugged into the wall outlet. Also, try temporarily plugging directly into the wall outlet to eliminate any issue with the surge protector; plug a different electronic device into the same wall socket to make sure the socket works, and also try the iMac's power cable in a different wall outlet.
  • Make sure the computer's power cable is firmly connected to the computer.
  • If any external devices are connected to your iMac, disconnect them and try to turn the computer on again. If the iMac will power up when those devices are removed, but not when they are connected, contact the manufacturer of those devices for assistance.
  • Try resetting the iMac's SMC
  • Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer.
  • Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    1. Shut down the computer.
    2. Unplug the computer's power cord.
    3. Press and hold the power button for 5 seconds.
    4. Release the power button.
    5. Attach the computers power cable.
    6. Press the power button to turn on the computer.
Nov 12, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
I have a Kingston Data Traveler 2GB USB Flash Drive which I bought 2weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
We have all had it, yesterday it was fine now it says it doesn't recognise ya USB device.. AARrrgg. Well there are various way to try to fix. Now providing your USB aint Kaput then this works like 99 outa a hundered.Simply Remove and reinstall all USB controllersTo remove and reinstall all USB controllers, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
  2. Click the Hardware tab.
  3. Click the Device Manager button.
  4. Expand Universal Serial Bus controllers.
  5. Right-click every device under the Universal Serial Bus controllersnode, and then click Uninstall to remove them one at a time.
  6. Restart the computer, and "Windows" will then automatically reinstall the USB controllers.
  7. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Remember with USB devices. FIRST, install software/drivers, then insert USB device SECOND.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Plugged alluratek ahdu350 to a mac, and the mac doesn't recognize
Firstly make sure You are not connecting it via a hub or extender but directly to motherboard ports [ ports "sticking out" of Your mac computer], secondly make sure the enclosure has no loose connections,
Please note devices like hard drives are real power hogs, just usb connection may not be enough power, You should have a power adapter You can plug to a wall outlet to give extra amps to Your device
Should it power on fully, make sure to go to system details [you go there by ressing a button in "about my mac" little window from the apple logo menu and check under usb listing if it is listed
lastly go to disk utility and check if the drive is visible, if it is not mounted it may need formatting
Jan 13, 2010 | Aluratek AHDU350 USB 2.0 Hard Drive
An error has occurred while initializing u3 launchpad:drive H is unavailable or unformatted.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive
Nov 21, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
SanDisk Cruzer 4GB Micro - not recognized by computer
Well I have the same problem as Mark. I once couldnt eject my PC properly from my office PC & after that my SanDisk Cruzer micro 2GB pen drive is not recognised in any other PC. But I have tried other USB's they open & work perfectly. And I cant again insert my USB in my od\ffice PC cause they have blocked all the USB's... :(
Please help me urgently... I really need to uyse my pen drive urgently....
Jul 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
2GB USB Flash Drive
Hi. Here are the steps:
1. Plug your flash drive into a USB port on your computer.
2. If you use Windows, the flash drive will appear as an icon in the "My Computer" window, with a caption along the lines of "Removable Device" or "Flash Drive". Note: Please wait the first time you plug it in - Windows needs to "discover" the flash drive, and will essentially set itself up to recognize the device so that it's usable. If you use a Mac, the flash drive's icon will appear on your desktop with similar captioning mentioned above.
3. You can double-click on the icon to open the flash drive and see its contents. You can drag files from anywhere into that window, or over the flash drive's icon itself to copy files into it.
Mar 20, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Usb flash drive
It is simple to use, simply plug it into a working USB port on your computer and Windows or Mac will detect it as an external drive device. You will find the new drive under My Computer. The bottom right may display a "found new hardware" or something similar. Once you find your drive, open it and choose what you want to put on it. Just drag everything you need onto the new drive. There is a possibility that you have to format it first. Do do that, just right click on the drive device and choose Format. Use FAT or FAT 32. To remove the USB drive, find Safely Remove Hardware close to the time, right click it and select remove. This is more important on a MAC because data could easily get erased if removed without giving instruction to remove it.
Oct 29, 2007 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
