Question about Garmin nuvi 1490T GPS Receiver
Hi i bought 1490 garmin second hand, problem is there is a 4 digit code and i cant use it. is there a way to reset this code or is it useless to try
  • 2,574 Answers
Tip
Garmin Nuvi 1490 Favorites Backup and Restoration Procedure Models: Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1490 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1490 Manual Download
Garmin Nuvi 1490 QuickStart Download
Garmin Nuvi 1490 Webupdate
Garmin Nuvi 1490 Hard Reset
on May 27, 2010 | GPS
Hi, i need to do a "Hard reset" in my Garmin nuvi 1490
power the unit on and immediatly place your finger in one of the corners and hold it there. I believe it is the top right but if it doesnt work the first time try a different corner. This will reset the entire device and erase all settings.
Mar 05, 2010 | Garmin nuvi 1490T GPS Receiver
Forgot my 4 digit pin
try this link >>>
http://www8.garmin.com/support/userManual.jsp
Jul 30, 2009 | Garmin nuvi 265 Car GPS Receiver
Tip
Download Garmin Nuvi 1490 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1490 GPS?
Would you like a digital copy of the Garmin Nuvi 1490 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1490 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1490 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1490 GPS?
Would you like a digital copy of the Garmin Nuvi 1490 Users Guide for easy searching of terms and quick reference?
The Nuvi 1490 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
GARMIN LOCK
Hello!
Place your thumb nail in the groove located under the Garmin logo on the bezel.
Gently pull off the faceplate.
Press the reset button.
If it still asks for a code and you don't have it, it should ask you to drive to a secret location to unlock the device. If you don't know the location, the only other option you have is to send the unit to Garmin to be unlocked. You can also try to call Garmin with the serial number and see if they can do something less annoying to unlock it.
May 31, 2009 | Garmin StreetPilot c550 GPS Receiver
Tip
Garmin Nuvi 1490 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1490 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1490 series GPS unit.
I hope that helps.
on May 27, 2010 | Garmin nuvi 1490T GPS Receiver
Tip
Garmin Nuvi 1490 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1490T GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
