Question about Itouchless Bm003l Bio-matic Fingerprint Door Lock
ITouchless door lock reset - Itouchless Bm003l Bio-matic Fingerprint Door Lock
Where can I find instructions on how to rest the finger print and number pass word for my iTouchless BM001 BioMatic Fingerprint Lock Keyless Entry Handle. I bought it at target but lost my instrutions, please help
Posted on Dec 02, 2013
Touchless soap dispenser will not stop
wipe the sensor or the entire machine with water
Nov 17, 2013 | Itouchless Touchless Soap Dispenser -...
What is the default code of itouchless door lock
Refer this inquiry to itouchless for validation and resolution
Jun 28, 2013 | Bio-Matic Fingerprint Door Lock Silver...
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
How to replace the battery?
have you googled it you will be surprised whats on there hope this helps
Jan 21, 2011 | Itouchless Bio Matic Fingerprint...
ITouchless trash can won't close all the way anymore
When the lid is open notice a metal pin that slides thru the lid to the body of the can. With needle nose pliers, pull out pin to the right and remove lid. Now push the manual open button and quickly turn of power button. Now put the lid back on and slide pin back in. Now turn power button back on and see if this corrected your problem.
Oct 10, 2009 | NRS iTouchless Stainless Steel Automatic...
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Itouchless Bm003l Bio-matic Fingerprint Door Lock Logo
618 people viewed this question
Top Itouchless Home Security Experts
Lawrence Oravetz
Are you an Itouchless Home Security Expert? Answer questions, earn points and help others
