Question about Sebo Felix Classic Bagged Upright Vacuum
The vacuum sucks but the roller won't turn. The green light won't come on. The screws on the back are too tight to turn. We think it's the belt but are not sure. Can you verify? Thanks
Buffalo12980
  • 625 Answers
SOURCE: hoover windtunnel U6439900
please go to the hoover vac store using the following link. you will have your exploded diagram for the machine and any spare parts you might need. http://www.thehooverstore.com/U6425.html
Posted on Sep 15, 2007
reddevil6
  • 1673 Answers
SOURCE: New Eureka vacuum cleaner belt keeps slipping off
You may have a bad brush roll, part #61250-1, or the base itself has a problem and isn't letting the brush roll sit straight so it can be in alignment.
Posted on Jan 15, 2008
SOURCE: Replacing a belt on a Sebo Automatic X1 vacuum cleaner
The roller brush has stopped turning, I think it could be the belt, how do I seperate the top from the bottom?
I will await your reply.
Thankyou Val
Posted on Sep 30, 2008
SOURCE: Carpet roller will not turn. Vacuum still sucks up dirt
It IS true that you can take the plastic cover off the top of the carpet head. But in addition to removing the two Phillips screws at the bottom, you have to manouver the wand release a bit. Loosen the screw and carefully pull the release back just as much as you need to, to remove the cover.
You will also need to pull manually release the four clips - two at the back and two on the sides - to pull the cover off.
However, I did all this and found that the plastic setting holding the roller canister in at one end had been burned out so that the roller didn't sit properly. Nothing I can do to fix it except order a replacement. The original problem was caused by getting carpet ends caught up in the roller. This caused the burning.
Posted on Sep 28, 2009
Vac Belts
  • 701 Answers
SOURCE: the vacuum sucks good, but the brush on the bottom
Even tough the belt is intact it still might need to be replaced. Here is a replacement:
Dyson DC14 Belt and Manual
Posted on Jan 10, 2010
Titan power brush not turning
I had a similar problem,cleaned mine too and it looked clean but what i found was hair tightly wrapped around the spindle under the end rollers so tight you could hardly see them,they were pulled right in and it was a nightmare to remove.Try holding the two rollers and get someone to spin the brushes it should spin with rolling a finger over it.mine was not the same machine as yours but they all work the same good luck.
Dec 07, 2013 | Miele S2181 Titan Vacuum Cleaner
What causes my Shark Vacuum to work only intermittently?
If the brush roller operation is intermittent, there may be hair jammed inside the end caps. The brush roller can be removed and the end caps also for inspection. Intermittent operation also can be caused by a stretched drive belt.
The periodic failure to pick up may be caused by something such as a ball of hair migrating through your vacuum cleaner and stopping from time to time to test your patience
Jun 26, 2013 | Shark Navigator Bagless Upright Vacuum
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
My roller bush won't turn ever time i put a new
1) you need a little tight the belt, with the bolts of motor.
2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor.
3) the motor you must test for brush, switch, or open winding.
4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord.
God bless you
Jul 23, 2012 | Vacuums
Motor runs, brush won't turn, burning rubber smell
Easy to fix. The burning rubber smell is hair in the roller against the belt! Congrats, you have a healthy vacuum, you are lucky! Unplug the vacuum, remove the screws that cover the belt and roller brush. If you are nervous, take pictures with a cell phone or digital camera as you go for re-assembly. ok, pull the long roller out of it's slot and out of the vacuum. cut all hair off the roller and carefully move the belt from side to side to do the same. If the belt slips off, it slips back on easily. If the area is too tight for fingers guide it back on with any long thin wooden object. You can squeeze the belt to narrow it and slide it back over the thin metal rod that spins it from the motor. Slide the roller through the belt and back into it's slots. If it won't slide back on, turn it a quarter turn. Repeat till it does slide back into place. Put the face plate back on-tighten screws, flip it over, plug itr in and it should work!
Sep 05, 2011 | Bissell Vacuums
My Hoover brush spins, but doesn't have very strong suction. I've checked the filter, tubes, but it seems as though something is stuck inside. Can you tell me how to check behind the roller to...
To get the roller out.Turn the machine upside down.You will see some screws.Remove them.That allows you to remove that plate.The roller will just lift out.Some have a cap on it and can fit tight.On the back of the machine are two more screws that hold the hose on.You can take the hose off there ,if you have not already.Running a straightened out wire hanger through the hose will insure that there is not a clog you may be missing.As it is a few years,replace the belt while you have the roller out.It is on one end of the roller and the other end slips on a small wheel.It is easy to do and may improve the over all performance of the vacuum.
May 16, 2011 | Hoover U8145-900 Savvy Bagless Upright...
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Jul 21, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Sebo Felix Classic Bagged Upright Vacuum Logo
69 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
