Caps lock led not working - Computers & Internet
  • 93 Answers
Sometimes electrical components needs to have all power sources removed and reintroduced to work properly. Try performing a hard reset first, if it doesn't work then try updating your BIOS. If neither works...It's pretty much dead and not worth fixing.
To Perform A Hard Reset
  • Shut down the computer by going to the Start menu and selecting shut down. (If you have no display, hold the power button down for 5 seconds)
  • Disconnect the AC Adapter from the notebook.
  • Remove the battery from the bottom of the notebook. There will be a switch/button to eject the battery.
  • Wait at least 1 minute with all power sources disconnected.
  • Re-insert the battery and reconnect the AC Adapter and then attempt to power on the computer.
Posted on May 22, 2011
Caps lock indicator not working easynote
You should go to service to check if the led is still ok or needs to be changed.
Apr 15, 2013 | Packard Bell EasyNote E2 316 Notebook
KEYBOARD CAPS LOCK INDICATOR ON SCREEN NOT WORKING
Try this http://caps-lock-indicator.com/ or this http://keyboard-leds.com/
Dec 14, 2012 | Toshiba Satellite Computers & Internet
My cap lock works, but the led light doesn't work on my HP dv6000 laptop.
Does your number light work when you toglle the number key?
Mar 24, 2012 | HP Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
How to know the Cap Lock is on or off for my Microsoft wireless keyboard 4000?
I don't have one of these keyboards, but there is usually a small led built into the caps lock key to indicate the lock is on, Push the caps lock key, and observe if any leds are changing state. If they are, it's the indicator led.
Otherwise, you will have to open Wordpad and type...to see the state of the key. It's possible the led isn't working, so check it's state in Wordpad.
Good luck, and hope this helps.
Feb 13, 2011 | Microsoft Wireless Laser Desktop 4000...
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
