Question about Lexmark Wheelwriter 3000 Typewriter
Wheelwriter 3000 by lexmark
I just received this typewriter w/o a book and when I hit the tab it beeps.
Can you tell me why and how to correct the problem?
Thanks,
Joanne
  • jpl826 Aug 18, 2008
    Thanks so much... I did both suggestions and it worked. Thanks again for this solution. This website is awesome!!!
    I tired both suggestions and it worked! This website is awesome. Thanks again.
  • Lexmark Master
  • 3,594 Answers
Move the carrier all the way to the right an touch the R. margin key. You should also check the batteries, if they are corroded replace and clean up the contacts with some sand paper.
DickyO
Posted on Aug 15, 2008
We have ibm wheelwriter 3000. When typing it makes a beeping noise. Tried to release margins, but still beeps
If it beeps on every key stroke try code "S" If it beeps once in a while it may be the spell check code "1" will turn that off. If it always beebs at the same place the R. margin is probably set there. Space all the way to the R. and press R. mar key.
DickyO
Aug 16, 2011 | Lexmark Wheelwriter 3000 Typewriter
I have a wheelwriter 300. when i hit the tab key, after just turning on the typewriter, the carriage moves only as far as hitting the space bar. if i hit it again, it jumps about 2 inches and then stops....
Put a little shot of WD40 on both sides of the the silver shaft that the carrier slides on if that doesn't do it some WD40 on the carrier motor bearings. The front one can be reached from inside the T/W
the rear either you must remove the case or fish the straw tru the case. The motor is in the R. rear corner of the T/W.
DickyO
Jun 27, 2011 | Lexmark Wheelwriter 3000 Typewriter
Will not print my job
If you need an instruction book go to lexmak.com there may be an answer in the book.
DickyO
Mar 15, 2010 | Lexmark Wheelwriter 15 Series II...
How do i change the font size on a Wheelwriter
The font size is set by the printwheel, the printing on the P/W case will tell you the pitch 10, 12, 15 or PS. Change the wheel change the pitch.
DickyO
Dec 07, 2009 | Lexmark Wheelwriter 3000 Typewriter
Tabbing
Have you set a tab where you want it to stop? If it wont keep tab settings after being turned off it may need batterys.
Jul 23, 2008 | Lexmark Wheelwriter 10 Series II...
Typewriter freezes
Your description is a little vague, does it type letters and freeze when you hit the space bar or or just stop on all keys?
DickyO
Jun 23, 2008 | Lexmark Wheelwriter 3000 Typewriter
Wheelwriter 10 Series II doesn't work
My repair book shows:
1 Make sure the printwheel in installed correctly. 2. make sure the ribbon and correction tape are installed correctly 3. turn the typewriter off wait 30 seconds then turn back on if the same thing happens install another printwheel. 4 turn the typewriter off wait 30 seconds then turn it back on if the same thing happens call for service.
Jan 17, 2008 | Lexmark Wheelwriter 10 Series II...
IBM Wheelwriter 1000 - How to clear all tabs
Using the space bar move the carrier (print head) all the way to the right, press and hold tab clear key and hit the return key.
Dec 14, 2007 | Lexmark Wheelwriter 1000 Typewriter
Need a user manual
Oil rails not with WD. Machine oil.
I have instruction books $ 10.00 828-687-3929
Sep 28, 2007 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 3000 Typewriter Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
