Question about Vacuums
Small fir from cooking pot pie. package burned. after cleanup, no visual damage. pulled fuse it, seems to be blown-no reading on ohm meter. What other parts should I order before pulling it off wall? I was thinking thermostat for cavity.
  • 43,501 Answers
There is a very good chance that the only problem is the fuse. I would try that before checking any further and spending money that you do not need to spend. It is very hard to tell at this point if and what else may be damaged..
I would get at least a couple of fuses though...they are not expensive and you may well need more then one till you troubleshoot it completely.
heatman101
Posted on May 23, 2011
Dyson upright vacuum with kinked cord kept stopping. There was a loud bang and smoke and the vacuum stopped. Has the motor blown up, or can it be repaired?
This happens a lot the supply cable bending or damaged shorts out causing smoke and a bang if fitted with or backed up with a high amperage fuse .
check length of supply cable if you find damage/ burning smell,
either replace cable, or you could fit a inline rubber socket and plug by cutting out damaged part of cable and fitting female part of plug first into supply cable 1. then on the vacuum side of cable fit the male part of plug 2 . supply 1. -----o o----------2.--- vac
using insulation tape if you like you can tape plug and socket together to stop it pulling apart, normally cable damage will not damage the vacuum cleaner. and fit the correct fuse rating for the machine 1000 watts at 240v divide 240 into 1000 =4.166 amps
so with a 1000 w load you do not need a 13 a fuse fitted 6 amp fuse should be ok. or go online and see what is recommended re fuse size for appliance ,
Nov 12, 2016 | Dyson Vacuums
How to replace power cable on hoover jc3157t
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Jan 04, 2014 | Hoover Vacuums
No spark,no power to ignition module
Do you have power to the fuse? Sometimes fuses look good, but are actually bad. Check with volt-ohm meter. otherwise bad connections and or wire, corrosion causes a lot of bad behaviors, clean to bright metal for all connections and contacts. Again check with volt-ohm meter, or "indicator" light method.
Nov 03, 2012 | Clymer Harley-Davidson Dyna FXD Evolution...
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
Sharp R-1480. Microwave would not start - jarred door, and it heated and worked. Replaced bottom of the 3 inter-lock door switches. Turns back on - all seems normal. No heat (it does overall sound...
Hi Mark,
It sounds like you have a magnetron problem now or at very least a rectifier that is shorted.
The elevated sound level comes from one of those two components. But since you had a door switch problem I would lean toward the problem being internal to the magnetron. It is common for them to over draw on the circuit going through the door switch before they fail completely.
To test the high voltage components you need a good ohm meter, the magnetron should read under 1 ohm from terminal to terminal and infinite ohms from either terminal to ground. The rectifier or diode should read 0 or low ohms in one direction and high or infinite in the other. BE SURE THE POWER IS OFF BEFORE SERVICING!
Apr 24, 2010 | Vacuums
I have a simplicity 6 series vacuum. the bag overfilled and vacuum will not run. No power. is there a fuse of relay inside the unit?
no just on /off switch and direct power to vac motor sounds like its burned up from bag being overfilled , now you have to get to the vac motor test it with switch on to see if its getting power if so then motor is burnt.use an ohms meter for power test.
Feb 07, 2010 | Simplicity 7250 Deluxe Vacuum
My dyson vacuum has no power.
Get an ohm meter (found on basically any multimeter), also called a continuency meter. its the setting that beeps when you have a straight line running from point a to b on a wire.
Unplug the vacuum. Test the cable from the plug to where it goes into the switch.Turn the switch on and test the points at the switch. Test the 2 wires running from the switch to the motor. make sure the 2 wires are plugged into the motor. Make sure the brushes on the motor is making contact with the armature. if they all test good, your motor has blown and will need replacing.
Oct 28, 2009 | Vacuums
Vacuum will only start if I pull out the cord very hard
The Miele interior is not too complicated. Look at this site for some instructions on opening it, http://www.sannerud.com/house/miele.html Then use visual inspection or an ohm meter to find out where the connectivity problem is.
hope that helps
Jun 08, 2009 | Miele S514 Solaris Bagged Canister Vacuum
My hoover keeps cutting off and on, now it doesn't even come on. I have checked the fuse its ok and i can't cheak the wireing,the plug is moulded into the socket.
Chances are your cord was damaged inside the insulation and over time it finally opened. That would cause the cac to not operate any more. If you have access to or one of your friends has a multimeter then you can check the wiring by using that meter in the OHM mode... and placing one lead on each of the two plug terminals at the end of your cord ( not plugged into power of course ) and put the vac switch on.. you should not see an open circuit and read something in the range of 10's of ohms to 100's of ohms ...depending on what path it takes.. ( meaning that with the switch on.. you should be measuring resistance through the motor windings and/or light bulb ..if it has one... That would be a quick test of your wiring integrity... Hope that helps..
Aug 21, 2008 | Hoover Vacuums
Hoover u8173-900 think motor is bad but how to disassemble
Is this a Savvy? If so your problem may be in the handle switch asm or one of the circuit boards. The switch is really a problem, but they have come out a hopefully a better one. If it is the motor, take it aprt, you can check it with an ohm-meter to see if you have reading or if it shows an open. If it isn't froze up, and has an electrical burn smell, then the field of the motor is bad.
Apr 27, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
