Question about Kitchen Ranges
I need to know how to set the control panel on my Turbosoft 56mt320 water softner. It was set YEARS ago and I need to advance family capacity to better soften my water.
  • 34 Answers
SOURCE: installing culligan silver series water softner
If you have to ask call a plumber. This is a task for a pro. I have spent years as a plumber and I still hate doing these thing. It will take a pro 4-6 hours to hook one up. But if you still want to try here we go...
You will need to find tohe water line comeing into your home. Sometimes you are lucky and they are inside the garge some times the line comes up inside and outside wall. You will also need a power outlit near the unit and the water line....This will take a full page to type so if you really want to do this my email is bigslimaba@yahoo.com if you email I will write it out for you.
Posted on Feb 04, 2009
  • 659 Answers
SOURCE: water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Posted on Mar 31, 2009
gary1121
  • 332 Answers
SOURCE: Water softner dirty water
you might also want to check into the piping in your house is it gavinized, cpvc or copper, this could also make a diffrence, you could also be pulling mud from the bottom of your well, the anoid rod in the water heater will keep you from seeing this in the hot side lines,suggest to have a test done on the water take a jar with a lid and take it to your local plumbing supply house and see if they can't have it tested then you will have all your answers, the test i'm in md. it cost us aprox 40.00 to have the complete water test,
Posted on May 30, 2009
  • 101 Answers
SOURCE: Water in the detergent, fabric softener, bleach dispensers
If it's not leaking outside I wouldn't worry
Posted on Oct 02, 2009
SOURCE: After each wash the fabric softner compartment is
When is better to add the fabric softner to the dispenser.
Posted on Dec 11, 2009
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Have a 30yr. old mark 20 culligan water softner which still works
You should not have to adjust the brine setting. Just the days per week. The salt dosage is dependent on the capacity. If you cut back on the days used you will still need to use the same amount of sodium to regenerate the softener.
RJ
Apr 03, 2009 | Culligan Sediment Water Filter Heavy Duty
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
No hot water
After you replaced the control did it heat?? If so replace it again.
May 27, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I have Kenmore 3.5 super Capacity, PART # 48102. It no longer goes full cycle, stopping during or just before the rinse cycle. It also no longer dispenses bleach or softner.
I dont know about it not going through the full cycle, but as for the bleach and softner dispenser problems, i had the same issue. About 7 months after i had this same machine,,, the softner would enter the cycle during the first rinse, which i supose isnt a major problem, but it was quite annoying because by the time the 4th rinse was over,,, there was obviously no softner left on the clothes. It was still under warrenty so i had sears come over. They replaced the control board, thinking it was a timing problem, but it didnt solve the problem. They scheduled me for another time, and again sent over a repairman who didnt know what he was doing. I being 20, like to take things apart and see why they broke or how they work, so i pretty much knew what the problem was. I told this second guy what i thought and he ordered the part, 2 weeks later came back after i had recieved the part, installed it, and PROBLEM SOLVED. So im thinkingthis could be the same problem your having. If you take out the detergent draw to clean it or for whatever reason, if u look inside, and up,,, you can see holes where the water drops from,,, and that is the part you probably need fixed. I really cant remember what the part is called,,, but im assuming its something like Detergent Dispenser Asembly or somethng like that.
May 25, 2008 | Kenmore Washing Machines
My Axxis wfr 2460 is not releasing the fabric softner from the drawer
You could try a tooth-brush. And after you fill your quantity of softener, top it with water till the exit level of the compartment. You could also check whether water actually pours into the compartment during the final rinsing of the clothes; in this case you should check the inlet pipe screens of your inlet pipe into the machine; which can be done without opening up the machine.
Nov 30, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Help new born baby washer not working:(
it is due to the problem in the microprocessor it is set like that to on the pipe to fill water after four cycles and no mechanical parts controlling it and it is controlled by the processor so u have to call them for assistance
Jun 29, 2007 | Indesit W 123 Front Load Washer
Fabric softner leakage
By opening upper machine's cover you will have an access to the detergent/softner drawer. Look for the place the water leaks from. Good luck !!
Sep 03, 2006 | Maytag PAV2300 Top Load Washer
Kitchen Ranges Logo
273 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
