My pen stopped working - Computers & Internet
  • 27,725 Answers
if you are refering to a usb drive
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on May 22, 2011
S Pen for my Samsung Note 3 stopped working how can I fix it
Samsung Galaxy Note 3: S Pen stopped working on screen:
Hello. The S Pen is not powered by a battery per se. The screen on your phone generates a magnetic field. There's a coil inside the S Pen that captures energy from the field to power the pen.
1. Question are your S Pen options turned off?
Settings>Controls>S Pen>
turn on Direct Pen Input
turn on Air Command
turn on Air View
etc..
2. it could be the pen tip that is worn out and needs to be changed. Check the tip by pressing it into the pen with your finger.. if you feel the tip going into the pen too far, it's probably the tip that is broken or worn out. Some customers say buying new tips is too much trouble, and getting a new OEM Samsung S Pen made for your Note 3 is a safer option.
3. it could be the wacom digitizer screen that is having problems on your phone and needs to be fixed. If you had fixed the screen prior, it could mean the person who installed the replacement screen could have did a bad job.
4. if you are using a magnet closure case, try taking it off and then using your S Pen. Because the external case magnet can interrupt the magnetic field the S Pen uses for power rendering it useless, until you remove the magnetic closing case.. and then all should be well again.
5. You can do tests on Note 3's that are not carrier locked by dialing *#0*# (this is not a solution but it can help eliminate possibilities)
DIAGNOSTIC TEST your Pen for Samsung Galaxy Note 3
6. If you bought an Aftermarket knockoff S Pen, that's probably the problem right there. A lot of non OEM Samsung S Pen's have their own issues and work for only some things.
7. You can try fixing the sensitivity of the S Pen
8. Buy an original Samsung Galaxy S Pen. A Note 1, 2, 4, or Note 5 S Pen will work for your Note 3, but it may not fit inside the Note 3's internal compartment/holder. You can try buying a used one to save money, but be aware that you might have to change the tip
Feb 08, 2016 | Samsung Galaxy Note 3
Install ok and works up until I touch the pen to the tablet - the blue power light starts flashing and the tablet stops working/freezes - what could be the problem?
you are shorting out the computers by useing the pen if you go into setings and look for the pen and then set it up it shoud stop it happning
Jun 28, 2015 | Computers & Internet
My Genius Mousepen 8x6 tablet isn't working with the pen. If the pen touches the tablet, the light lights up, but the cursor doesn't click and it won't move either. The mouse is working fine, though.
My i608 pen stopped working today. I've had it for a month. The mouse was working fine, but the pen wouldn't work at all. Then I left the mouse on the pad and used the pen while the mouse was on the pad, and the pen started working again. Now it works even without the mouse on the pad. Did it re-establish the radio connection or something by doing that? Anyway, saved me the $25 replacement cost.
Nov 25, 2010 | Genius MousePen 8x6 (MOUSEPEN8X6)
My pen doesn't work on my tablet pc. It suddenly stopped working
Does your tablet have an LED to indicate it's being powered? If so, it must be the pen.
Does your pen have an internal battery? If so, it's time to replace it.
Aug 21, 2009 | Toshiba DIGITAL TABLET PC PEN FOR PORTEGE...
My tablet pen stopped working
http://abiamy.com/abiyasablogs/2008/04/06/fixing-a-broken-wacom-pen/
Aug 26, 2008 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
C pen 20
I found a solution before asking help from c-pen support.
1. Uninstall C-Pen software
2. Remove C Technologies entries from registry. They appear in HKEY_CURRENT_USER\Software and HKEY_LOCAL_MACHINE\Software
3. Reinstall C-Pen software (remove the pen from USB before reinstalling)
This worked in my system(Vista 32-bit).
Apr 04, 2008 | Xerox One Touch 2400 Flatbed Scanner
Gateway tablet screen does not respond to pen.
I have a Gateway CX2724 and previously had another Gateway tablet (model I don't remember) but they both look alike and use the same pens. I've had 3 pens and they all periodically stop working. When one stops, I pick up another pen and work with it so that makes me think the problem has more to do with the pen. (They have all died and later come alive.) Sometimes though I can't find the extra pen and have resorted to removing the working pen tip / nib and reinserting it very snugly after wiping off the shaft. The nib is held in merely by friction. You can remove it by pinching its little tip between your fingernails and pulling it straight out. I wipe off the shaft and put it snugly back in. Sometimes I don't take it out, but just press it harder into the pen by pushing it firmly onto a padded surface (so that the tip doesn't deform.) Usually one of these "treatments" works. I know that extra nibs are available with the pen. There must be some reason that the manufacturer thinks they may need to be replaced periodically. But I've never seen any documentation on this.
Sep 30, 2007 | Gateway M275 Tablet PC
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
