Question about Dell Inspiron 2200 Notebook
I have a Dell inspiron 2200 My screen goes black but you can see the program running in the back faintly. If I use a flash light I can still use the laptop. I power it off and at times it will work well, then all of a sudden it goes black again
  • 915 Answers
The laptop has a faulty backlight. This could be either the backlight inverter board or the CCFL (cold cathode flourescent lamp). The inverter is more likely to be at fault than the CCFL. The fact that it sometimes works for a while suggests either a dry joint or bad capacitors. If you want to try to fix this yourself you will need atleast some soldering experience. The backlight inverter is usually mounted in the display. It may require significant disassembly of the laptop in order to access the backlight controller. Check the PCB for dry joints and replace any electrolytic capacitors on the PCB (a capacitance meter can be used to check the capacitors if you have one).
Posted on May 22, 2011
  • meemee shah May 25, 2011
    i am facing the same problem some people told me that my dell inspiron 1545's screen goes black because of some problem in the socket where i plug in my laptop charger, or it is because of the over heating .. so i was advised to check the both i did but i am still facing the same trouble i have hardly used this laptop its been just a year ...please tell me what should i do
Dell inspiron one 2305 black screeen with one flashing light
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Apr 18, 2014 | Dell Inspiron One 2305 Desktop Computer...
Inspiron turns on but not monitor
That is good, it proves the problem is in the laptop display, the most likely issue is the inverter board, "located just below the LCD screen" the other less likely is the backlight just behind the LCD display.
Apr 06, 2012 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 boots up but 1-2 min in the screen goes to a faint black. You can still see the desktop and everything just very faintly. Like a fain transparent black.
Check with your Power Plan or screen saver option, you might have it adjusted to super energy saving to make your battery last longer and have the screen dim, or backlight shut off since you mention it take 1-2 min to boot up ...see if that might help.... If that didn't do the job, I suspect your backlit lighting might be going bad. Let me know what Operating system you are using too. So like I said, check your screen save and if it is set to dim, or shurt off withing a minute or two... set it to something longer to see if that works.
Jan 15, 2011 | Dell Inspiron 2200 Notebook
I got a laptop Dell Inspiron 2200...I turn the power on and all the four (4) green lights goes on then flashes a bit a wont turn on... ANY CAN HELP ME.... Thanks
If the the four lights on the computer come and then go off. Then these are the diagnostics lights telling that the motherboard has gone bad and needs a replacement
If they flash in some sequence . The the problem could be with one of the internal components.
For more information on the same you can visit www.support.dell.com
Thanks for using fixya
proton
Jul 28, 2010 | Dell Inspiron 2200 Notebook
Black screen on laptop
Call Dell For replacement backlit screen it happened with mite to the DELL
Sep 21, 2009 | Dell Inspiron 1100 Notebook
The screen is blank but I can see a faint image.
Try reseating the cable that goes to the back of the lcd and also the other end of that cable that plugs into the motherboard. If that doesn't do it then either the lcd or the inverter is bad. Either way when you get a replacement screen for a dell laptop it normally comes with a new inverter as well. If your laptop is under warranty thru dell then you can get it replaced thru them. If you have your serial number then I can look it up and see if your system is still under warranty.
May 26, 2009 | Dell 0JM629 Inspiron 1520 Keyboard
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Dell inspiron 2200 is not powering up after being switched on, its on black screen! help
The most probable cause of failure is the memory sticks on the computer. Follow the troubleshooting steps given below and you would be able to get the system up
http://tinyurl.com/5gmvww
Thanks
Proton
Donot forget to rate the solution if it was helpful or resolve your issue
Jul 26, 2008 | Dell Inspiron 2200 Notebook
Inspiron 2200 series
Try a system restore.
 On boot up hold down F8
 you should get a black screen and among other listing will be start from last know time the machine worked[or word to that effect] use the up/down arrow to get to it and hit Enter.
See what happens
Come back if not go we will try another way.
Oct 23, 2007 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
