Question about Whirlpool 25-Pint Dehumidifier
Just purchased this product and we are having difficulty figuring out the best setting so that the unit will shut off and on. It seems to only run continious. The model no. is VK0025000CURNPF735A0794 SERIAL NO. NPF735A0794. We are using it in our basement that is approximately 600 sq. ft. We have the humidity level set at 55 % on low fan speed. How can we get it to shut off and on and not run continuiously? Thanks
  • Whirlpool Master
  • 3,740 Answers
When a humidifier is first placed into service depending on the environment you placed it in, it can take up to a week to actually shut off.
Think about this...
Q? Why did you buy the unit in the first place?
Ans. Area you want to use it in is damp.
So the NEW humidifier has to really work hard to remove moisture from everything in the space.
Furiniture, structure to include cement floors and walls. This can take a very very long time initially. If there is a sump pump in the basement the humidifier needs to be placed quite a distance from the sump area. If the structure foundation and walls are allowing water seepage into the basement it may NEVER shut off.
If it does not shut off after several days. Move the unit to a small room upstairs that you can place it in and close the door just to test to see if the unit will cycle on and off. If it cycles on and off in a small room you may want to inspect your basement foundation and check for plumbing problems.
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
When turn off. makes a humming sound. compressor seems to be running.
Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My Dehumidifier goes on for 3 minutes & shuts off. Cleaned filter, adjusted humidity settings, & moved unit to different areas of basement.
heatman101
Aug 05, 2011 | Dehumidifiers
I purchased a 65 pint LG dehumidifer # LG LHD65EBL. This is the second one that I have had. I had to return the first one because it would not shut off when bucket was full. This one runs for about a...
First, tunr the unit OFF and unplug it for 10 minutes. Then plug it back in and turn it ON. It will automatically set at 70%. Press the - button and lower the humidity extraction level to 45% in increments of 5%. Once you reach 35% press and the - button one more time. Now the unit is set to run continuously, until the bucket is full and the unit turns OFF automatically or you manually turn the unit OFF. In case you have misplaced the Owner's Manual, I have included a link to it, that you can download and print. http://aic.lgservice.com/gcsc/dwn/main
I hope this helped you and thanks for choosing FixYa..
Jul 29, 2011 | LG LHD65EBL Dehumidifier
Is there any way to run automatically. . . where when it reaches humid per cent it shuts off? Can you rig to run for x hrs. per day and then shut off and restart the next day?
Norman, once the unit reaches the extraction level you have it set for, the unit will turn OFF automatically. However, depending on the humidity level in your home, it may take several cycles of running and emptying the bucket until it reached. After that, it should turn OFF, once the level is reached. Then when the humidity level rises above the setting it's on, it will start up again.
Since your unit is a Manually Controlled unit, there's no safe way to "rig' it to run on with a timer. The plug in wall timers are not rated high enough to handle the load of the dehumidifiers operation. Trying to use one, would fry the timer and possibly the dehumidifier.
If you want all the features you mentioned, you will need to purchase a new electronically controlled dehumidifier.
Jul 05, 2011 | Amana D545M Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
It seems the unit fan runs but the condenser doesn't work. When first turned on the fan runs and the display shows 85%, with the setting at 55%, and four hours later the fan is still running but there's...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jan 16, 2011 | Frigidaire FDF50S Dehumidifier
Compressor runs, overheats and shuts down..fan does not run...
I have had the same problem. Following the advice of someone on these pages I opened the machine up and checked the fan with a meter. On my model (the 404) it has two settings so two leads; one seemed okay, the other was dead. I checked the circuit where the fan connector plugs in and I got that both speed settings were supplying plenty of juice. Apparently the fan motor is dead. A replacement runs $79 at http://www.appliancefactoryparts.com/. I ordered one; we'll see what happens.
Apr 11, 2009 | Goldstar DH504EL Dehumidifier
DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Aug 05, 2007 | LG DH30 GoldStar Dehumidifier
Dehumidifiers Logo
191 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
