Question about HP Photosmart C6180 All-In-One InkJet Printer
I have an HP Photosmart C5100. Problem, I am overseas and cannot get any more replacement cartridges. Is there a way to continue to print grayscale even though one or more of the color cartridges are empty?
    Guru:
  • 731 Answers
Hi David,
HP Photsmart printer, work in TIJ (Thermal InkJet) technology, for printer to function; you need to have all 6 ink cartridges.
Regards,
Riztech
Posted on May 23, 2011
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
How do I get my photosmart D7260 to print black and white only? I have changed the settngs to grayscale only using the black ink cartridge, but I continue to receive color prints.
Hello Shaw ,
When setting to grayscale , click on the " High Quality " arrow and select " black ink only " .
Best regards ,
fanaudi .
May 10, 2011 | HP Photosmart D7260 Printer
I just replaced the cartriges in my photosmart C6180 after it was in storage for months. The error I get is 0xc18a0408 which is an ink system failure. How do I fix this so that I can print again?
hi
go to this link and read the informationed about ink cartridge . after a while the ink dries up and needs to be replaced, as well the printhead may need attention (possible replacement)
if you need (extra information) some part numbers to order , see inofrmation below .
C9087-60023 Service station assembly - For conditioning the ink cartridges when the carriage is in its home position
C9087-60008 Ink delivery system assembly - For the Photosmart C7100/C6280/C5100 All-in-One printer series
cartridges = http://h20141.www2.hp.com/Hpparts/Search_Results.aspx?mscssid=0938C619D0FD4908A7A1F4891CAB246F&SearchIn=Product
manual = http://h10032.www1.hp.com/ctg/Manual/c00753187.pdf
hope this helps -- if it does, would you please rate my service to you
Nov 14, 2010 | HP Photosmart C6180 All-In-One InkJet...
Color Cartridge out of ink - override/print in grayscale?
Printer will not print if any color is out. Just won't. They are set up like that.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
May 28, 2017 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C7280 still prints in color
Why don't you try changing the Setup for your printing to Black & White or Grayscale in your computer's software: File/Print/go to the printer's settings and disable anything color. As for the cartridge, it's probably the cartridge. If you have an extra, why not swap it out? I believe the brains in the cartridge contacts might not be working properly OR your heads need to be cleaned OR you better stick with HP original cartridge to make sure it's not the printer. I used to use "odd" ink and even refilled ones and shortly thereafter my old printers would die. Not taking a chance on this HP. I love how it prints when it isn't jamming the paper! Need help on that problem pronto.
Jan 06, 2009 | HP Photosmart C7280 Laser Printer
MyHP Photosmart C5180 has stopped printing colors and all ink is
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Solution
Complete the following steps to resolve this issue.
Step one: Check the printin grayscale setting
If the self test page printed in color, the ink cartridgesare okay, and the ink levels are well above empty, the printer software hasprobably been set to print in grayscale. Follow the steps below to check thissetting:
  1. In the software application you are trying to print from, click File, then Print. The Print dialog opens.
  2. Make sure your printer is selected, then click Preferences. The printer Preferences dialog opens.
  3. Select the Color tab, then make sure that Print in grayscale is not selected.
  4. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved, you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved, continue to the next step.
Step two: Check the inkcartridges
NOTE:- HP cannot guarantee the quality or reliability of non-HPink.
  1. Check the ink cartridges to determine if they have been refilled. If they have been refilled, try replacing them with genuine HP ink cartridges.
  2. Try the print job again to see if this step resolved the issue. If the issue is not resolved, continue to the next step.
Step three: Check inklevels
Replace any empty print cartridges.
  1. Press Setup .
  2. Press clip_image001.gifto select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed.
Figure 1: Ink levels
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
  1. Try the print job again to see if this step resolved the issue. If the issue is not resolved , continue to the next step.
Step four: Service theproduct
If you have completed all the steps listed above and arestill experiencing a problem, service the product.
Nov 23, 2008 | HP Photosmart C5180 All-In-One InkJet...
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP 7550 PhotoSmart Printer prints photos with an unpleasant green hue.
If it's a B&W or sepia photo, and you wanted to print B&W or grayscale anyway, pull the color cartridge (assuming a 2 cartridge system). I did that with my HP DJ 5440 and it works perfectly.
May 14, 2008 | HP PhotoSmart 7550 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
