Question about Orangex Ojex Citrus Juicer
I need a rubber tip for the press mechanism on the orange-x medium juicer. mine has rotted after much use.
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
How to make orange juice from fresh oranges
Peel 4 medium size oranges and place in the juicer.
Juicing Tip: When juicing oranges (or any kind of citrus fruit) it is a good idea to juice the white membranes at the center of the orange. The majority of the bio-flavonoids in citrus fruits are found in the white membranes. Scrape off some of the white membranes inside the peel and include them in the juice. We don't recommend juicing the whole peel, this will produce a very sour unpleasant juice.
Nov 29, 2010 | Jack Lalanne Power Juicer 250 Watts
My Acme 5001 Juicerator vibrates around on the countertop. The rubber pads seem to be falling apart. Can I replace them? Where do I get them? Thanks David II
Dave, contact Waring at 1-800-492-7464 and order
a new foot ring. Here's a tip. When the juicer is
not in use find a bowl cover or something to fit
in side the circumference of the foot ring for the
juicer to rest on. That way the foot ring won't
stick to the counter and rubber won't compress
over time.
Nov 09, 2010 | Acme 5001 Supreme Juicerator Juice...
Need a manual for acme juicer 6001, juicer at least 30 years old
The juicer hasn't really changed over time, but you
need to be a little mechanically inclined to adjust
and keep it running properly. Call Waring at tel
1 800 492 7464. Good luck. Mine is 21 years
old and running like new.
Jul 30, 2010 | Acme 5001 Supreme Juicerator Juice...
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
Motor won't work on Champion unless I press on part
it probably has developed a loos connection inside. Pressing on that part reconnects the loose connecion inside the machine. If you are someone with a good mechanical aptittude, you may open it and somehow make a hood connection again. The problem should be obvious, and straight forward to fix.
Jun 27, 2009 | Champion G5-PG-710 650 Watts Juicer
STRIPPING DOWN THE JUICER FOR CLEANING
Yes.  There should be an orange handle-looking accessory with to small metal rods sticking out that is made to clik into the wire mesh screen and unlock it be twisting the screen mechanism slightly so you can unscrew it out.
See the enclose photos of the tool.
Hope this helps...
-enov8
Mar 03, 2009 | Jack Lalanne Power Juicer (Stainless...
Orangex Ojex Citrus Juicer Logo
29 people viewed this question
Top Orangex Juicers Experts
eyecam
David Payne
David Payne
Tom Chichester
Are you an Orangex Juicer Expert? Answer questions, earn points and help others
