Question about Grilling
Witch side of the grill do you want the fire to be on??
    Brigadier General:
  • 4,736 Answers
That depends on what type of grill you're using (gas or charcoal) and what you're grilling. Do you want to use the direct method of grilling or the indirect method?
Posted on May 22, 2011
How long would I need to cook a 151/2 lb crown roast fo pork on a Weber grill. It has 18 ribs
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. Be sure to cook over the cool side of a two-zone fire and rotate every once in awhile to even out which side faces the fire side.
Dec 23, 2017 | Weber Grilling
How do I download Bubble Witch Saga 2 to my Kindle Fire
Press the GAMES, in CLOUD mode.
On the top right side press STORE. SEARCH GAMES is at top in small letters, write " Bubble witch saga 2." You have several choices and they are FREE. My favorite word!
Nov 08, 2014 | Amazon Kindle Fire HD
Fire ring don't sit level on fire box
Had the same problem. Instuctions show a different ring (smooth on one side, grooved on the other) they say to keep notches facing up. My ring had grooves on one side and large square notches on the other. Due to the way the ring is tapered, the round notches face down, opposite the instructions . And plate warmer fit better. Short answer: flip the ring over.
Sep 03, 2012 | Big Green Egg Large All-in-One Grill /...
As I typed previous gas is coming out of all the ports on the burners on the gril. They are not clogged. but gas does not travel around burner and get to one side. The holes have been cleaned. the BBQ is 3...
When you removed the burners to clean them, did you also check and clean the venturi valves and the burner valve(s) orifice(s). If not, this may be the problem, as the burner(s) are not getting all the gas and the proper air to gas ratio, that they need for complete combustion.
R H Peterson the manufacturer of Fire Magic Grills has been around for years and makes one of the best high end grills on the market. Their Technical Service Department is top notch, so if all else fails contact them at 800-332-3973 or the Fire Magic Dealer you purchased the grill from.
Mar 20, 2011 | Fire Magic Aurora Island A660i-2A1N Gas...
I have a fire Magic A660 drop in grill (natural gas) and when I light the burner (2 of the 3 burners) the flame doesn't travel all the way around the burner. Gas is coming out of all the ports. I can light...
I don't know how old your grill is, but as grills age, the gas ports in the burners begind to clog and corrode. Flame travesl around the burners like dominoes when you stand them up and knock them down, one port lights the next, etc. All burners light on just one side and there are ports that are designed to take the gas from the outside of the burner to the inside and from one side to another. Depending on how clogged the ports are, you can clear them using a straightened paper clip, or a drill with a bit. Be careful not to make the gas ports larger.
Mar 18, 2011 | Fire Magic Grilling
Need firing order spark plugs 98 chev express 1500
I am going by the '99-'06 Full size truck Chilton's Manual. The firing order should be the same. It is 1-6-5-4-3-2 on the v-6 engine. 1,3,5 are on the driver's side from grill to firewall and 2,4,6, are on the passenger's side from grill to firewall(this is in the heads). From the boot coming off the main coil(the only one not going to a spark plug) clockwise the firing order on the distributor is 5-1-3-2-4-6. Also make sure the plugs are gapped at .060 in. Hope this helps.
Sep 14, 2010 | 1998 Chevrolet Express
How to make a smoker frpm a stndard grill
on a standard grill you build fire on one side of grill and put food on the other you can also put a pan ender food with water in it
Aug 15, 2009 | Grilling
Grill's fire won't stay lit
Try banging on the tubes feeding the burners with a heavy pair of vice grips or a hammer. It usually shakes the carbon loose to allow for free flow of gas.
Aug 09, 2009 | Grilling
Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
May 29, 2009 | Char-Broil CharBroil 4637318 Grill
Grilling Logo
18 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
