Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Murray 11/36 ride on lawn tractor. Model 7-36508. In search of a manual for it - not been lucky enough to find one, Need to replace the belt for the mower bed and not sure what size to get
mowerman1857
  • 389 Answers
SOURCE: need parts for old murray rider mower 36 in
If you send me your email address I will send you a PDF file of the parts for your mower
m o w e r m a n 1 at h o t m a i l dot c o m
Use correct format and without the spaces
Posted on Sep 17, 2009
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
SOURCE: Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
Posted on May 31, 2009
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
  • 3911 Answers
SOURCE: MOWER BED LEVELING
Get the mower on a flat slab of concrete. Raise the deck all the way. Make sure the blades are on correctly. Measure the distance from each corner of the deck to ground. Lower the deck and take the same measurements. You will find, if you look, some threaded rod/bolt and/or pin settings to make adjustments. Most often the deck is out of whack as someone took it off and did not put it back on correctly. Google the mower's make and the word "'manual" if you cannot figure it out. Someone out there will provide you with a manual if you cannot figure it out from looking at it and there will be instructions in the manual as to making the adjustments.
Posted on Jul 07, 2010
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Belt diagram for a murray 46 model 46573X92A
This has a couple of diagrams with belts. Hopefully it has what you need. If not let me know and I'll keep looking for you.
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-46573X92A-LAWN-TRACTOR-(1998)-PARTS-LIST.pdf
Jul 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Can't figuire out how the belt goes on need murray riding mower drive belt diagram for 42910X92A.
You should be able to get your info here:
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-42910X92A-LAWN-TRACTOR-%281996%29-PARTS-LIST.pdf
Oct 24, 2009 | Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I Have a Lawn General Riding Tractor, I think it's made my Murray. The drive belt keeps falling off. It is model #42504x71a. Ser. # 7386702081f00626. The belt is not real old. A service center says that...
Hi, service manual and parts can be found on amazon, here:
manual: Amazon com lawn general riding mower manual
parts: Amazon com lawn general riding mower parts
after reading manual you can be able to detect your problem and see if you need new part or just small fix. I hope this helped you. Have a nice day
Jun 04, 2009 | Garden
May 31, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
589 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
