Question about Lexmark X1240 All-In-One InkJet Printer
Help! Thanks again.....It did download the driver for X1250 Windows XP, but that doesn't seem to work when I want to print. It pulls up another window with my document in it called "Microsoft Office OneNote 2007 and doesn't allow me to print. Any other ideas? :) Thanks again....I really appreciate your help! Dawn
  • 659 Answers
Hey there just to let you know that if you goto the http://www.lexmark.com website and do a driver search for the z600 series that those drivers will work with the x1240 I have heard it works so I would like you to test it out and give it a go and see if we can get it going.
Posted on Aug 17, 2008
SOURCE:
When i give a print command this error apears on the paper : pcl xl error subsystem:kernel error:illegaltag operator:0xfe
1st: turn off your printer, wait 5 minutes, turn on again. Try to print again and see if the problem is solved. If this doesn't work:
2nd: de-install your printer from your computer, download the latest driver for your operating system, install your printer again. And if this doesn't work, download the latest HP Laserjet generic driver and install it again.
You can find the drivers on the support page from HP, searching for the model printer that you have and select the driver for your operating system (windows xp, vista, 7..)
Aug 07, 2011 | HP LaserJet 1320n Printer
I have installed HP 1220c printer on windows 7 in several ways. Printer seems istalled OK, when I try to print test page or other, the printer doesn't react. Although the print appears and dissapears...
Unistall any previous you have installed for your device.
The Driver for Your Product Is Included in the Windows 7 Operating System (i.e. Win 7-32bit & 64bit).
Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product.
Hope it helps.
May 30, 2011 | HP DeskJet 1220c InkJet Printer
Need driver for my lexmark x1250 printer
ok you can download drivers here http://driverscollection.com/?H=X1250&By=Lexmark for windows 7 and http://www.nodevice.com/driver/X1250/get44581.html for xp make sure that you archiving tool winrar or winzip if not go to http://rarlab.com/ and download it,thank you for using fixya
Jan 15, 2011 | Lexmark X125 All-In-One InkJet Printer
Lexmark X1240: tried to uninstall and reinstall
Please make sure that the printer is actually VISTA compatible (it should say it on the box) If it is compatible then there is a good chance that the drivers need to be updated. (even if you just bought it) Your first option would be to download the driver directly from Lexmark.com (forget the CD that came with it) Your other option is to download the drivers for LEXMARK X1250 (I have tried this many times with other printers and they worked just fine) I have also used these two web sites to download the drivers for other printers and it seems to work ok so far. Here are the links to the X1250 http://driverzone.com/device.php?id=81664 http://www.siliconguide.com/drivers/device/112/ ...Best of luck to you, I hope I was able to help.
Apr 24, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lexmark lv X1250 drivers
Here is driver download page from Lexmark. Select your operative system to enable download.
After downloading file run it.
Keep printer USB unplugged while installing drivers.
Aug 18, 2008 | Lexmark Office Equipment & Supplies
Help!
goto this website listed above and scroll down to the bottom you will see a enter validation code then download button do this to grab the drivers for xp for your x1240
you can also check the lexmark for the x1250 drivers and see if they have it for xp as well since they are the same unit and use the same drivers
hope this helps and let me know if you need further assistance
Aug 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark z25 drivers for windows vista
I have the same problem. The Lexmark printer z 25 do not work on windows Vista. Please give a solution.
Feb 09, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark won't work with vista
Yes works with Vista but you will need to use Vista driver not XP
Rate this solution then Download here
Delete old install before reinstalling!!!!
Release Notes Attention: To prevent issues during the installation, please uninstall all previous versions of this driver prior to installing this web package. File Information File Name: cjr1200EN.exe null.gif Version: 1.0.11.3 null.gif Released On: MAR 05 2007 00:00:00 null.gif File Size: 42452912 KB null.gif Products: Lexmark X1240, Lexmark X1250, Lexmark X1270, Lexmark X1280, Lexmark X1290 null.gif Languages: null.gif Operating Systems: Windows Vista null.gif Application: n/a null.gif Owner Name: Lexmark null.gif Data Stream: Lexmark Host Based Solution, Lexmark Scan and Copy Control null.gif Security: null.gif Install Instructions:
Dec 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
