Question about Yamaha Audio Players & Recorders
I get the message "speaker
    Brigadier General:
  • 8,546 Answers
Have you looked in the manual?
I'd start disconnecting the speakers one at a time (from the receiver end) until it stops, then isolate the shorted wire or speaker.
Posted on May 23, 2011
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
Sony STR DE835 receiver - no sound from speakers and headphone jack
The problem is in the audio output semiconductors, they have shorted causing the fuses to blow and it is in auto protect mode to prevent further damage. I recommend a professional to assess.
Mar 10, 2012 | Sony STR-DE835 Receiver
Cant get front left and right speakers to produce sound....when i try to use the receiver remote to turn up the decibals on the front speakers it wont go past "0"...it will go into the negatives...
1. Speaker B instead of A selected??? Page 53.
2. As far as the Fronts limiting to 0 dB, they are the reference for all others. Perhaps the engineers thought it made no sense for the stake in the ground to have a moving reference level. See step 3 on Page 50.
http://www.retrevo.com/support/Yamaha-HTR-5830-Receivers-manual/id/394ci070/t/2/
Jan 22, 2011 | Yamaha HTR-5830 Receiver
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
Speaker Err on Yamaha Home Theater Unit ???
I am assuming this is the message that shows up from your receivers front display panel? It could be the receiver is telling you that you may have the neg & pos. wires crossed and in the opposite position either in back of the receiver speaker posts, or in back of the speaker terminals themselves. My Yamaha receiver has this nice feature where it will tell you when the speakers are "Out Of Phase" which describes the problem I have described here.
Just go back and make sure your wires are hooked up correctly, and use tape and a Marker to label pos. and neg so they will be easier to hook up next time you have to move the system, or decide to change some aspect of your system. I would then take the time to label every wire that goes to each speaker that you plug into the back of your receiver. This a BIG time saver........
Apr 10, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
ERR message appears
Press the RESET button on the rear of the unit while it's turned on. After that unplug the AC adaptor and wait a while before plugging it again.
Jul 31, 2009 | JVC RA-P11 Portable Audio System - Made...
Unit will turn on, but no sound, also displays "OFFSET" error
The typical cause for this amplifier damage or a short on the rear panel.
Check your speakers terminals to make sure they are secure and that there is no stray wiring from the speaker cables that can make contact with anything other than the binding posts.
May 08, 2009 | Audio Players & Recorders
Receiver standby/on switch is flashing and cannot turn receiver back on
Try checking your speaker cables as one of them may be touching the case of the amp,or touching another cable,this can cause a short and cause the error message.The amp is protecting itself .
hope this helps.
CABLE GUY.
Jun 30, 2008 | Pioneer VSX-917V-K Receiver
Speaker errror message
The usual fix for "Speaker err" message is to simply unplug the sub-woofer power cord to reset the speaker diagram, plug it back in and remember to "match the negatives to negative, positives to positives" and never try to replace the original speakers with anything but equivilent speakers, adding on more speakers can cause the "Speaker err" message and an inoperative system.
Jan 21, 2008 | Audio Players & Recorders
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
