Question about Acer AL1916W 19" LCD Monitor
ACER 1916 monitor works for a while, then periodically power-cycles itself and powers-on with the Acer logo. This happens sometimes every 10-15 minutes, sometimes I can go hours with no problem. I visually inspected the power supply and controller boards for anything obvious - cold solders, solder bridges, popped caps/transistors, etc. Also cleaned the controller board and connectors with isopropyl alcohol. No change. I made sure there is plenty of ventilation around the monitor and put the 120v on a UPS.
  • 11,361 Answers
Service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1916&kategoria=&kat2=all
http://s807.photobucket.com/albums/yy352/budm/ACER/
You need the check the voltages before and after the problem occurs, that will be the first palce to start. Worst case will be the lamp assemblies; http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 23, 2011
Testimonial: "I was afraid that I might have to dust off the DVM and/or O-Scope. Thanks for the link to the manual. I'm sure it will help."
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
I have an Acer AL1916W monitor which powers up and shows the Acer logo and then cuts off. It seems to do this when on for long periods.
Please inspect the DC filter caps in the power supply, see failed ACER due to bad caps first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Aug 31, 2010 | Acer AL1916W 19" LCD Monitor
Acer 1916 monitor..Power button flashing but won't turn on
Look for bad caps in the power supply first, post back what you see inside so we can guide you furhter, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 10, 2010 | Acer AL1916B 19" LCD Monitor
Every few minutes brings up box 'No Signal'. Sometimes when powering on ACER logo thing takes a few minutes to disappear.
I have a Acer moniter too. Seems like you have a loose VGA cable or not enough power going into the video card
Jun 04, 2009 | Acer AL2423W LCD Monitor
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Acer Al 1916 W mind of it'e own
you need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Jul 21, 2008 | Acer AL1916W 19" LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Acer AL1716 Power problem?
i have experienced the same problem (power cycles on and off and on and off... nothing but Acer logo and black screen) on 2 Acer model 1706 A version 1706 Ab monitors both built in July 2006. Before the customer reported the 2nd monitor with the same problem, i sent the 1st one into Acer for warranty service (after testing in on 4 machines w/4 different video cards). They shipped it back with a paper saying the monitor was repaired. I returned the monitor to the customer and it exhibited the same symptoms (aka, not repaired). Could there have been a bad batch in July 2006? When I plug a new Acer AL1716 monitor into the same computers, I have no problems at all.
Jan 18, 2008 | Acer AL1716 17" LCD Monitor
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
889 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
