Question about Dewalt Heavy - Duty 4 - 1/2" Small Angle Grinder - D28110
Can't figure out how to attach the diomond cutting disc to grinder, they say nothing in the instruction book
    Sergeant:
  • 281 Answers
Check the backside of the arbor plate on the bottom sometimes they have a step that will fit the wheel mounting hole.Just take them off and turn the bottom one over.Hope i explained this clear enough.Thank you for choosing FixYa.com.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 22, 2011
Misplaced my angle grinder's inner disc flange
If you use a nut, the arbor nut will not hold your grinding/cutting wheel properly and you'll use up threade the arbor nut needs to tighten. What you need is the clamping flange, Bosch part number 3603340501. If you have a tool repair center near you they may have one or can order you one. If not, you can get one on sites like www.ereplacementparts.com.
Dec 06, 2012 | Bosch 1800 4 1/2" Angle Grinder Cutoff
My makita 4 1/2 grinder has a problem where the motor still turns but the mounting shaft and subsequently the disc does not move. Its not had more than a few weeks work so is almost new.
Inside the head of your grinder there are a couple beveled gears, one on the armature and the other on the spindle that the discs attach to. If either or both gears are broke or worn down to where they don't contact each other properly, the motor will spin but not turn the spindle. It's easy to disassemble the head to check but if the tool is that new you may want to look into getting it repaired under the warranty.
Jun 15, 2012 | Makita Angle Grinder 4.5" 9524NBX
I just bought a hand grinder from a guy but don't know how to take the disc off . it has a button u push but no nut on the disc
If there isn't an arbor nut holding the blade/disc on the grinder you have a disc with the threaded center built into it. While holding the arbor lock button down you have to turn the disc by hand until it breaks free and spins off. It may be on vary tight as it is a self-tightening thread so the disc won't come off while you use it.
Feb 22, 2012 | Black & Decker Black And Decker 4-1/2"...
I have a D28110 angle grinder and I want to use a 1/8"cutting disc with it. Do I need a different guard than what it came with?
haven't heard of a different guard for the cutting disc you want to use. Most people remove the guard when using them
Sep 15, 2011 | Dewalt D28110 Heavyduty 412" Small Angle...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
Hi, I'm trying to change the fiber disc on a DeWalt DW402 but after pushing the locking button on top I'm not able to unscrew the wheel. If I turn counterclockwise the wheel turns, but it seems I...
  • 1 Check the grinder before you begin. The newer discs on rotary grinders have patented buttons that allow you to remove the disc without any tools. You may have one like that. In models like this, there's usually a spot to depress and then remove the disc.
  • 2 Turn off the grinder before you attempt to remove and change the disc on your rotary grinder. If it's battery powered, put the grinder in lock position so you can't accidentally turn it on. If it's electric, unplug the grinder from the wall.
  • 3 Look for a nut in the center of the disc. This is a give away that you need to use your special wrench. Sometimes the grinder comes with a tool necessary to loosen and remove the nut. Other times you need to use a wrench.
  • 4 Lock the wheel into place before you begin. You can find a button or switch at the side or back that allows you to do that. When you lock the wheel in place, the disc remains still as you loosen the nut in the center.
  • 5 Remove the nut in the center with either the tool provided with the grinder or a shop tool and lift the disc off your rotary grinder.
  • 6Lift the disc off the rotary grinder. If you have different discs, remember to check for the best fit. Put the nut back on a different way for different discs. Check for a rim and indentation on one side of the nut and a flat side on the other. A visual inspection of the disc for the rotary grinder gives you information about the side to use.
  • Here is a diagram of your grinder and the tool you are looking for is number 50...
    http://www.ereplacementparts.com/images/dewalt/DW402_TYPE_6.pdf
    Jun 11, 2011 | Dewalt 4 1/2" Small Angle Grinder D28402
    I have a Makita 100mm Disc grinder what attachments are available for this older tool...model M952
    as its a grinder...there are not many attachments available....just your common grinding and cutting discs.
    Aug 06, 2010 | Makita 9553NB 4" Angle Grinder
    Instruction book for Grizzly florabest FSG130 chainsaw grinder
    Hi Fixya........contacted ....info@grizzly-gmbh.de and they sent a copy of the instrution book by e-mail........problem solved, thanks...Mike
    Sep 04, 2009 | Grizzly Saws
    I borrowed a B&D 7750 3 to cut off the legs on a wire shelf system. I would like to replace the grinding disc but it appears to need a special tool to remove the disc. Is that correct? The owner says...
    Yes you need an angle grinder spanner/wrench. It is like a tool with two pins that fit in the holes of the grinder disc securing nut. You can see a picture of one here: http://images.toolspot.co.uk/Angle%20Grinder%20Accessories/Angle%20Grinder%20Spanner%20For%20412in.jpg
    They do come in different sizes, but you can also buy adjustable ones. Your best bet is to take the grinder to the local hardware store, big box outlet or anywhere power tools are sold and they should have a grinder spanner to suit your grinder.
    Jul 03, 2009 | Black & Decker 7750 4 1/2'' Small Angle...
    How to....
    most angle grinders arrive with a spanner; two if it is quite old. if you are not experienced with such tools and do not have the instruction book i strongly suggest you take a trip to your local hire shop and purchase a couple of discs and some goggles and explain your problem there. the staff there will be expert at giving tool virgins crash courses in the safe operation. dont forget a safety rcd for your electric plug.
    Sep 28, 2008 | Metabo W14 125 Ergo Angle Grinder 5"
    Dewalt Heavy - Duty 4 - 1/2"  Small Angle Grinder - D28110 Logo
    90 people viewed this question
    Top Dewalt Saws Experts
    Parson's Repair...
    Parson's Repair...
    JOHN LAPIER
    Are you a Dewalt Saw Expert? Answer questions, earn points and help others
