Question about Pyle Audio Players & Recorders
My Pyle pro PEXA plays good for 5-10 mins but then goes into protect mode but is not overheating
Duncan
  • 218 Answers
SOURCE: Amp protection mode
Try swapping the "bad" fuses for the "good" ones and see if that helps. That will tell you if the fuses are the problem. I doubt that is the problem. You never said what kind of problem you were having with the left speaker. If your friend dropped a drink into the amp then I would discontinue using it until it was checked out and don't be surprised if you have one channel that has some parts that need replacing, like some of the output transistors/MOSFET's. That might explain why your fuses appear to be melted. Maybe they are. In any case, get someone who knows what they are looking at to have a look see at your amp.
Posted on Jan 17, 2007
  • 631 Answers
SOURCE: my pyle amp keeps going into protection when i turn my music up and play it for a min
The most common cause is an unsafe load/speaker impedance. If you have the speakers wired correctly, you may have a short in the wiring. If the wiring is OK, the amp is likely defective
Let me know if you have any other questions.
Posted on Oct 14, 2008
  • 631 Answers
SOURCE: car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Posted on Oct 26, 2008
  • 120 Answers
SOURCE: Technics amp su-vx800 goes in to protection mode
yes it can, it sounds like its over heating, make sure that your product is able to get fresh circulated / cooler air
if it already is, then it probably is a faulty product.
Posted on Nov 23, 2008
SOURCE: keeps going to protection mode
My ? was answererd
im going to hook up a thicker ground wire and ground it to a better place.
my positive wire is as big as i could get and my RCA cables are the good ones
this is a great place yo get information. Thanks.
Posted on Mar 23, 2009
My mackie m800 fell an now it plays for about 30 to 40 min an then goes into protection mode the fan goes into high speed an it mute the audio
Sounds like it's overheating or otherwise overloaded. Check the front panel channel status indicator to see if it's a heat issue (hot vs. norm). I'm guessing there's a short at the output that's putting it into overload after 1/2 hr.
http://www.mackie.com/pdf/M800_om.pdf
Nov 07, 2014 | Audio Players & Recorders
Pyle 2210 how to test the amp when it keeps goin
when the amp goes into protect mode, it is more often than not a problem with the speakers or the speaker wiring.
Sep 01, 2014 | Car Audio & Video
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
Amp problem
why, why, why, that is the question here.
Sep 30, 2009 | Pyle PLA1200 Car Audio Amplifier
I got a pyle 1800w amp and a 1500w kenwood subs but as i increase the volume in the headunit it goes on protect mode why the other problem i got is as increase the volume in the headunit the bass of the...
The protection modes in these units ****. Most new units have them. What I do is turn down settings on deck and turn up amp as much as possible. Then the protection won't turn on because you won't have to turn it up as high.
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Car audio amp in protection mode
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
My pyle amp keeps going into protection when i turn my music up and play it for a min
Oct 13, 2008 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
Amp protection mode
Jan 17, 2007 | Pyle PT-3200 Amplifier Car Audio Amplifier
69 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
