Question about Altec Lansing Multimedia Computer Speakers
Altec Lansing ada745
My problem is the prongs on the right front speaker have broken off. Is there any way to rig up this speaker so it will work again. None of my speakers work now. I hate to throw them away and I called Altec Lansing and these are obsolete now. Cant get a replacement right front speaker(the only one with power to it)
  • denisehale Aug 15, 2008
    wonder if it will work if you break off the black rectangle on the ps2 plug
  • denisehale Jan 22, 2009
    I got tired of stepping over this sub and actually threw it in the trash a couple days ago...Well I dug it out and tried your solution and surprise....it worked. great I might add. It is full blast but I use my volume on my computer to keep from losing my hearing. I can only use 3 speakers but it sounds perfect. Thanks for coming to my rescue....:)
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
Oh, my goodness.  I have the exact same problem, and it just happened to me today as well, same model.  The fifth prong got bent in while I was trying to plug it back in after diagnosing a different issue (speaker volume would randomly jump up and down regardless of audio source).
It looks like a PS/2 style connector with one of the top pins missing, so I thought about taking an old PS/2 plug and grafting it on after breaking off one of those pins, but the center plastic block on the PS/2 connector is unfortunately keyed differently than the speaker plug (it's lower down on the PS/2 plug).
Posted on Aug 15, 2008
ALTEC LANSING ADA745 WILL NOT POWER UP
check whether the adapter is fine or not..
that may also be a problem...
Mar 26, 2008 | Audio Players & Recorders
Will I be able to hook my altec lansing ada745 to my sanyo dp39842
The Sanyo DP39842 only has a digital audio out. You'd need a digital to analog converter, a coaxial digital audio cable, and then an RCA to 3.5 mm audio cable. Here is an example of the audio converter: http://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA .
I hope this helps.
Mar 03, 2015 | Altec Lansing Ada745 Computer Speakers
Need help with altec lansing ada 745 4.1 speakers
Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to ..... Computer Speakers
Sep 29, 2012 | Altec Lansing ADA745 4 Speakers
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
Very low volume coming from speakers
i have exact same problem i think its got something to do with volume controller on front right speaker damn shame as the sound was awesome
Jun 02, 2010 | Altec Lansing ADA745 4 Speakers
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
Connect Altec Lansing ADA745 to HD TV RCA output for home theater
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
Feb 25, 2009 | Altec Lansing Multimedia Computer Speakers
1,126 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
