Question about Sharp R-209HK Microwave Oven
Does not turn on all the numbers on panel are zero's and blinking, did try unplugging still nothing
  • Sharp Master
  • 3,740 Answers
Flashing zeros are a sign of a momentary power loss. Usually you also get a Pf error also. Not always....
Try this and if it does not work let me know.
Press Stop / cancel
Press clock
Set time
Press clock
Attempt normal use.
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
Have frigidaire microwave and. Every time I try to set the clock it goes back to zero's # lfmv164qfa
That model does not apprear to be a valid Frigidaire US model number.
Did you try unplugging for about 5 minutes, then plugging it back in and trying it again?
It would also be helpful if you could describe in step by step detail what happens.
If you need further help, please verify the full model number from the tag / label and contact me via here.
Oct 12, 2016 | Frigidaire Microwave Ovens
Keypad won't work on model number hvm1540dn1ww General Electric microwave. How do I resolve this? I tried unplugging it and plugging it back in but nothing works
usually in this situation there is a problem with the panel just replace it there is a board behind it but iff the buttons dont respond then its most likley just the panel google the model number and you can get the panel
Nov 02, 2012 | Microwave Ovens
A small blinking light on the left upper corner of panel after a power outage and I can't do any command. The interior lights don't even come on when opening door. I already reset the breaker
Unplug the microwave oven for 10 minutes in a attempt to reset the microprocessor ic, press and hold the start button for the same time and release. Now plug everything back in hopes it will restart, if no change! the keypad control board will need to be replaced along with other unknown parts, due to the nature of damage far cheaper to replace.
May 09, 2012 | Microwave Ovens
We lost power several times last night during hurricane Irene. The power has been on for several hours now and I noticed the freezer LED display is reading "88" and the fridge display is...
If you don't want to roll the unit out, then turn the circuit breaker off in the panel. The quick disconnect does not reset the electronics for the compressor. Try that and see what happens.
Aug 28, 2011 | Microwave Ovens
Does not turn on. The control pad is lit but when you hit any button on the control pad nothing happens.
You have a failed membrane keypad. It's not uncommon for it to be intermittent or partially operable.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do it yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (with suffix) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Jul 09, 2011 | GE HVM1540DN 950 Watts Microwave Oven
Microwave is beeping all the time and can not press anything on the panel if turn it off and on sometimes can chance it and the quick on button will work and will cook ok but then it beeps and again and...
That's almost always a shorted keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
If you need further help, please feel free to contact me directly with your model number and symptoms.
Jun 20, 2011 | Sanyo Microwave Ovens
Stuck in demo mode on GE jvm1850 microwave tried unplugging, tried power level and zero at same time, tried holding clear, holding help, tried everything i have read so far but they seem to all be for...
A hard reset would be the first thing I'd recommend, but unplug it for about 2 minutes, plug it back in, and watch to see what it does.
Wait at least 60 seconds after powering it up to see if an "F3" code comes up.
You can download GE owner's manuals and installation instructions here. See what it says about a demo mode.
Otherwise, I would suspect a shorting keypad.
If you need more help, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 05, 2010 | GE JVM1850 1000 Watts Microwave Oven
Blinking lights
unplug wait 5 min then turn back on
Dec 09, 2008 | Sharp R-303CW Convection / Microwave Oven
Sharp R-209HK Microwave Oven Logo
204 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
