Question about Tornado Garden
I have the Tornado hedge trimmer ET2501 and it wouldn't start yesterday so I charged it overnight and it still doesn't work. I am squeezing the front handle,slide the lock off button backward and squeezed the trigger switch. It worked before and I have had it for about 4 months...please help.
  • 313 Answers
SOURCE: weed trimmer, cst 1000
common problem battery
Posted on May 29, 2008
slohry
  • 87 Answers
SOURCE: how to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Posted on Apr 09, 2009
  • 15 Answers
SOURCE: Homelite trimmer dies every time I squeeze the handle
This can also be (just did this too with my Zip Start):
1. Nasty Carb (loose screws or just funky)
2. Leaks (be they Air or Fuel Gaskets!)
3. Funky Exhaust Port
4. Fuel (check it ALL, lines, filter, tank)
5. Fuel CAP (believe it or not, they ARE vented for a reason, to PREVENT Vapor Lock)
6. The Spark Plug (if it is weak, she will act like that on the High Side, sometimes, even when Idling nicely! Double check your Plug Seat as well, where the Plug meets the Cylinder Head, if it is funky bad, clean it up, a good ground is a must!)
Remember that on a 2-Stroke, Spark Plugs take a hell of a beating on heat, or getting over-fueled (which they do, when carbs are unmaintained). And UNLIKE 4-Strokes....they have to burn OIL too! (Foul faster)
Fuel -> Fuel Filter-> Fuel Line-> Carb->
Splits here into TWO paths:
1. Fuel Bulb-> Fuel Line (Return Line)-> Fuel Tank
2. Fuel Bulb-> Carb-> Intake Port-> Piston-> Exhaust Port-> Exhaust Port Screen
Electrical:
Magneto-> Rotor Magnets (for Spark Plug, AKA- Ignition)->Spark Plug Wire->Spark Plug->Cylinder Head
Kill Switch (grounds all the above to the cylinder)
Running: (Carb, etc.)
Throttle Cable (super simple)
Carb Butterflies
Carb Seats, Carb Gaskets (air leaks/fuel leaks)
Needle Seat (Fuel Flow, Gummed UP!)
Any and ALL Fuel/Air Ports in the Carb.
Fixes: CLEAN THE CARB. I don't mean spray some WD-40 on it and call it "clean". Tear it ALL the way down (CAREFULLY!), and put her back together. Use some compressed air and Gum-Out.
NOTE: "Gasket Kits" are NOT a fix EXCEPT for leaky GASKETS!
They do NOT fix 99% of the problems: Spark Plug or Dirty Carb!
They will NOT fix "Operator Error" either!
NOTE: If it requires fuel (or a mix), it will invariably get gummed up, and nasty. Carbs are about the #1 reason ANY small engine fails, and ONLY second to people who will....not....maintain...equipment.
("Operator Error")
NOTE on Carbs: If it worked brand new without an adjusted carb (factory settings), it does NOT need adjusted now. What it needs to be is CLEANED, and put back into service. E.G.- MAINTAINED!
Posted on May 28, 2009
darth yoda
  • 4 Answers
try to adjust the air intake??
Posted on May 29, 2009
  • 508 Answers
SOURCE: engine starts cuts out when trigger squeezed
plugged fuel filter or bad gas
Posted on Jun 27, 2009
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
Our cordless hedge trimmer will start but keeps stopping after about I minute it won't cut bushes have tried to recharge. How long does it take and should a light show to indicate it is recharging. Th
Most chargers will show a green light when charged
That could take an hour
You have to or I do,charge all my items every 3 months
Not uncommon to have a failed battery in less than a year
Ideally four years & fair amount of use,but some do fail
Oct 29, 2014 | Bosch ASB Cordless Hedge Trimmer/Grass...
Worked fine for the first summer that I used it. However, a year later when it was time to cut the hedges again, the battery wouldn't retain charge and it only lasted about a minute. It was past its...
You will need to recharge the battery if you have not already, they drain with time. If you left the battery on the charger for one year, that is also not good for the condition of the battery either.
Aug 23, 2011 | Garden
My 10 year old weedeater hedge trimmer ran fine last year when I put it away for the season. When I tried to start it this year it wouldn't even fire. I put fresh fuel mix in and a new spark plug and...
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
Aug 19, 2011 | Weedeater 19 in 25cc Gas Hedge Trimmer
My 20" Black & Decker
Hi Frank,
If you're lucky there might be just a break in the flex somewhere or a loose connection in the plug.
Have a look at these tips I've written for problems with power tools.
http://www.fixya.com/support/r9189659-power_tools_not_starting_up
Jul 25, 2011 | Black & Decker Garden
CS26, couple of months old. Was using one day, stopped to get a drink came back to start and it wouldn't, rope pulled very easily and didn't sound like it was turning the engine. Opened it up and...
i was given one of these trimmers thats almost new but missing a bunch of parts so im seeking one that owner declares as 'junk'. ill buy and pay cash. locked up okay, blown engine ok, just need handle and body parts with aircleaner assly. anyone got one to sell me? seven06 three22 fourthree79. call mark, regards!
Jul 10, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
My 85 maxim will start if u push it and continue to start the rest of the day but once it cools down you will have to push it again any ideas
Sounds like you battery isn't holding charge overnight. If it was the alternator, it wouldn't start during the day so the alternator sounds fine.
Make sure the battery that is on it is the right one for the bike.
Try taking the battery off the bike and using a battery charger to charge it overnight. If that doesn't work, I'm afraid it's going to need a new battery.
Good Luck
Jun 26, 2011 | 1985 Yamaha XJ 700 X Maxim
Garden Logo
48 people viewed this question
Top Tornado Garden Experts
Robert Graf
ray gallant
Tom Chichester
Are you a Tornado Garden Expert? Answer questions, earn points and help others
