Question about Jet 3 Ultra Power Chair
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what would be causing the chair not to move?
  • 692 Answers
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
Posted on May 24, 2011
JET 3 ULTRA. WHAT SHOULD THE LIGHTS LOOK LIKE WHEN YOU TURN IT ON? THE CONTROLLER SHOWS ONE RED LIGHT IN THE LEFT HAND CORNER BLINKLING. YELLOW DOWN BELOW FOR SPEED CONTROL.
All the battery lights should be on and the yellow speed control should not be blinking. a flashing red indicates charging is needed. Strege Mobility
Oct 28, 2016 | Jet Health & Beauty
RED LIGHT FLASHING ON CONTROLER AFTER CHANGING THE BATTERIES ON MY JET 3 ULTRA. NOTHING WORKS.
make sure batteries are connected correctly and the connections are good.
Oct 26, 2016 | Jet Health & Beauty
New batteries installed, and flashing red lights, continuous, will not move
hi , how many flashing red lights are all of them flashing ?
Regards
Rob
www.gewizrepairs.co.uk
Jul 22, 2015 | Pride Mobility JET ULTRA 3 BLUE POWERCHAIR
Well i want to reset the whole thing because i lost remote 1 but i have remote 2 but it wont let me use remote 2 and on remote 2 i put new batteries but no blue lights flash up what should i do
well i think you are using a wii. If so then you must take the battery cover off the Remote. Then locate a button in the front of the wii next to the sd card slots. There should be a tiny red button. Hold it down for 2 to 3 seconds. Then do the same thing but with the wii remote. In the back of the remote should be a tiny red button in the bottom Left hand corner. hold and they should sync.
Please rate.
Dec 31, 2010 | Video Game Consoles & Games
I just purchased a used Jet 3 ultra power wheelchair...after charging it up I turn it on and the red light is flashing and it makes like a clicking sound when i try to make it go forward..cand you please...
bobby
The batteries are not charged. The red light indicates low batteries and the clicking sound you hear is the electric brakes being energized. Now the problem could be bad batteries or a bad charger. If you have access to an off-board charger (maybe a friend or acquaintance might have one) plug it into the charger port located under the front of the joystick. Don't plug in the on-board charger at the same time. Charge the chair overnight with the off-board charger and you should see a red light(power) and a green light(if the chairgot fully charged) if the light is still yellow then the batteries are bad and need to be replaced. Your chair uses 2 U1 batteries and if there is a battery store near you get them there. Interstate makes a good battery if you have a dealer near you. Hope this helps Good Luck
Oct 22, 2010 | Jet 3 Ultra Power Chair
Flashing red light batt. fully charged
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
Rapid flashing of red and yellow lights--batteries are new.
Make sure unit motors are in gear. Also batteries could be connected incorrectly.
Jun 19, 2010 | Jet 3 Ultra Power Chair
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
Someone gave us a Jet 7 Power chair and we've replaced the batteries and the fuse. I've checked all connections and everything seems ok. but I'm missing something because I'm still getting 2 flashing red...
Assuming it is a P&G controller (it'll say PG Drives technology on the bottom of the joystick), two flashing lights is a left motor disconnect fault. Check the wiring from and to the left motor for tight connections at all junctions. Unplug and replug them, don't just wiggle test them. This should clear the fault.
Oct 17, 2009 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra Power Chair Logo
137 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
