Question about Vacuums
I need a schematic for a Cobra CA-20 13.8VDC power supply & more impoprtantly, the SDS-120 transistor located therein.
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
I have Maytag counter top range mopdel # jed 843obde can I use 120 volts power supply?
CHECK OUT THE POWER RATING BEFORE YOU CONNECT.YOU CAN FIND THIS INFORMATION IN THE USER MANUAL.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Maytag Vacuums
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum faulty power PCB, Need service manual/schematic
No schematic found. The Q1 transistor is a 2N3904, D3 was replaced with a 1N4000 series.
Root cause still Unknown, but Q1 is an exact match and D3 is an acceptible replacement.
Hoovers solution is to replace the whole PCB no matter whats wrong with it, what a waste or good technology!
Mar 30, 2009 | Hoover Self-Propelled WindTunnel Bagless...
I bought a Bissell 1695 power steamer from a friend without a manual with instructions nor the attachments. Can you help please??
Hello, I went to a local repair shop & was told that I may as well trash this Bissell 1695 model because very few parts were available & none were what I needed. Of course, I have to research things for myself & to try to keep from buying a new power steamer. Called Bissell Customer Service. CSR told me that the model was discontinued, none of the parts that I need are available & referred me to five authorized KY dealers (all of which are an hour or more driving time away). I am going to call all of them tomorrow & hope I can find a solution to one broken pivot arm that holds rotating brush roll. I found a helpful website that has a schematic and lists all parts that are available to order (& unavailable). There is also one service note regarding the parts that I need that says the entire base assembly with brush motor must be replaced because of a design change. Of course, it's not available either. Hope this helps some. The website is: hescoinc.com
Dec 19, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
How do I wire vacume tubes and resestors together and what other parts are necessary?
Hi. It all depends on what you are constructing, and the type of vacuum tube you have.Most tubes are used as amplifiers so if you were making an audio amp an input device like a microphone will be needed, a power source to drive the tube (sometimes a very high voltage! ) and an output device like a loudspeaker.
I'd suggest checking out some basic electronics tuition websites to find out what else you might need, and maybe experiment with small transistor circuits first - they are a lot safer.
Jun 29, 2008 | Vacuums
Wiring Schematices
Connect as follows:
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
57 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
