Question about Garden
My Ryobi 4 stroke s430 ry34440 stalls when throttled trigger is pulled fully. Oil level is fine, gas is fine. does not idle.
    Sergeant:
  • 281 Answers
HI,
Use a stiff piece of wire and form a hook on one end and use it to fish the filter that is on the end of a tube in the gas tank.Buy a new one and you should be back in business.Hope this helps and thank you for choosing FixYa.com.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 22, 2011
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi s430 that starts and runs and throttles up fine when level but will stop if I tilt it to start using it even if I have the throttle pulled. Acts like its bogs down when not level.
Investigate the fuel line inside the fuel tank. Sounds like it may be split or cracked, or broken off. The line has a weighted pick up filter, and it is very common for the line to crack or break off so that when tilted, the line is above the fuel level.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Feb 25, 2017 | Ryobi Garden
Ryobi s430 will idle but will stall out when throttle opens. This carburetor has one idle adjustment screw and one fuel mixture screw.
Those carbs are a pain. Try arousing the idle screw, turun it to the right, then try to see if it will idle. You will have to tinker with the adjustment screw and the idle screw. Eventually you're gonna need a new carburetor. You can rebuild it, BUT , chances are those cheap carburetors never are the same.
Sep 13, 2015 | Ryobi Garden
Does a Ryobi trimmer S430 not use a fuel mixture?
the Ryobi S430 is a 4 cycle engine. As such it has an oil reservoir which takes 30 weight oil. It uses straight gasoline in the gas tank.
Sep 03, 2010 | Ryobi Garden
I have a Ryobi 768R Gas Trimmer, I just replaced the primer bulb and gas lines and had it running fairly well. It stalled on me while I was adjusting it and I can't get it restarted. I'd like to know what...
sorry not familiar with the 768R is it a 4 stroke or a 2 stroke?
Starting points for the HIgh and Low on 2 stroke carbs is about 1 full turn out for each
May 11, 2017 | Ryobi Garden
I have a poulan pro pp4620avhd chainsaw. I can get it to start and stay running as long as I have the choke on. I can even run it at high speed using the choke control. When I pull the trigger to feed it...
Check the fuel filter and muffler for plugging. Check the fuel lines for condition. Check the carburetor fasteners for tightness. If the saw has a lot of hours, remove the lower section of the carburetor and check the condition of the diaphragm--it should not be hard/cracked. If everything seems to check out ok, Turn both jet screws CW to stops (lightly), then CCW each 1-1/2 turns. The engine should start and run--allow the engine to warm up. Pull the throttle full on and adjust H needle CW til the engine speeds up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW so that the engine runs fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
May 11, 2010 | Poulan Pro Chain Saw 46cc 20"
I bought a Ryobi RY34420 yesterday from home depot
Sounds as tho it needs a minor carburetor adjustment. It's not getting enough fuel when you pull the throttle. Don't know if the owners manual addresses this issue or not, may want to check.
Dec 23, 2009 | Ryobi Garden
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
461 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
