Miele softtronic w 1734 waterproof fejl - Washing Machines
2 Suggested Answers
  • 6277 Answers
SOURCE: i have a miele washing
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 05, 2011
I have Miele Softtronic W435 Plus. Display showing: check wastewaterpipe. What can I do?
Make sure the discharge pipe/hose from the washer to the house plumbing is clear.
Nov 19, 2016 | Miele Dishwashers
How do I fix this myself: Miele Softronix W 1734. Reports Error: "F63" When I look up that error I get: "Contact Miele technician"
either the controller is not working or the inlet valve is bad .could also be the pressure switch that tells the machine when it is full enough
Jun 05, 2016 | Miele Washing Machines
Miele w1712 did not work...the machine was buzzer and when i saw it, it said waterproof fault
Hi dear,
There is a internal leak on your machine. You need to contact Miele to assist you. Thanks.
Jan 05, 2016 | Miele Washing Machines
How to reset miele wasmachine softtronic W3624
it may have a suds lock on it due to too much soap you may need to flush it
Jan 13, 2014 | Miele Washing Machines
Miele Softtronic T8423C only blows cold air..
If you are fairly sure that the power is reaching the clothes dryer, and the clothes drum is spinning, unplug the dryer first. Then using a continuity checker check the heating element. very often if the element needs replacing you will notice a break in the coil. Just like a light bulb, the heating element will eventually need to be replaced. The coil is the only source of heat, although it has components that operate it .
Dec 05, 2013 | Miele Dryers
Miele washer softtronics door will not open
go to this page and proceed according:
http://www.ehow.com/how_8562942_remove-door-miele-washer.html
God bless you
Jul 18, 2012 | Miele Washing Machines
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
My miele touchtronic w 3039 will not start. the waterproof system activated keeps blinking in the display window with the start button blinking as well and beeping
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Feb 16, 2010 | Miele W2203 Front Load Washer
Softner tray always full of water after washing cycle has finished, model is meile softtronic w418
Does your softener go into the machine at the appropriate time? That is, towards the end of the wash? If so good; it does not matter if the tray is full after the wash. Disconnect your hoses at your faucet to check if the water pressure is good; you could clean out the small screens while you are at it. Refit carefully.
Rate me pl........... if helped.
May 30, 2008 | Miele Washing Machines
Washing Machines Logo
431 people viewed this question
Top Washing Machines Experts
