Question about Garden
I have a 7055 earthquake rear tine tiller. I put 2 new belts on and when I start the motor the tiller takes off! What am I missing?
boscia
  • 163 Answers
SOURCE: older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Posted on Nov 30, 2008
KMusselmann
  • 247 Answers
SOURCE: I'm looking for the reverse belt routing.
Just take the old belt to a auto parts store and they can match it for you. If you dont have the belt take a piece of twine and put it around the pulleys
to make a template so to speak. Then take that to the auto parts store. Hope this is a FixYa. Pls rate the answer.
Kurt
Posted on Mar 21, 2009
  • 69 Answers
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Posted on May 06, 2009
  • 10865 Answers
SOURCE: rear tiller won't go into gear.belt needs replacing
find your model number from the list on this link and click to get your manual
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+rear+tine+tiller
Posted on May 20, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
I had this same problem and took the first advice about the shift fork arms being too spread apart. I took apart the gearbox apart and found that the shift fork arms did indeed spread apart overtime and with wear. I'm having a buddy weld some reinforcement to it as long as he can maintain clearance in certain areas as to not disrupt the operation. If it doesn't work then I did find the shift fork assembly part for $50, I just googled the part number, clicked on various sites, and found a better price!
Posted on Mar 03, 2010
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Why is the belt wearing out so quick, i have used my brand new earthquake rear tine tiller less than ten hours and have gone thru three belts.
-The pulley, idler are not line up and may be too sharp edges. or may be some other part is touching the belt when is running.
Good luck
mai
Jun 08, 2014 | Ardisam Inc Earthquake Mini Cultivator
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
I need a new belt on rototiller.
To replace your tiller belt you will have to :
Take a few pictures before you get started so you know how everything goes back together.
- 1) Remove the belt guard
- 2 ) Loosen the belt pulley and remove spring, remember how this was attached.
- 3 ) Pull the belt through housing and off of the transmission pulley.
Now grab your new belt and install in reverse order.
Feb 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Older model earthquake rear tine tiller won't start
Sep 30, 2008 | Ardisam Garden
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
