Air conditioner comes on but is not cooling the house....new house, new unit
  • 413 Answers
Try going outside and locate your outdoor unit. If the thermostat is on, and the fan is running inside, the outdoor unit should be on as well. If it isn't, locate the circuit breakers in your breaker box. There will be two. Trip them back and all the way forward.
If the unit is running outside, sometimes the air cond contractor forgets to come back and charge the unit with refrigerant. In this case be sure to contact the air cond contractor that installed the unit.
Posted on May 22, 2011
Tip
Air Conditioners Cooling Tips
  • Whole-house fans help cool your home by pulling cool air through the house and exhausting warm air through the attic.
  • Set your thermostat as high as comfortably possible in the summer. The smaller the difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be.
  • Avoid setting your thermostat at a colder setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing your power use.
  • Avoid placing lamps or TV sets near your air-conditioning thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
  • Plant trees or shrubs to shade air conditioning units but not to block the airflow. Place your room air conditioner on the north side of the house. A unit operating in the shade uses as much as 10% less electricity than the same one operating in the sun.
  • on Sep 21, 2010 | Heating & Cooling
    My air conditioner starts blowing like a fan before my apartment is cooled off, why does it kick off and on like this?
    When you first turn it on the fan runs and after a few minutes the outside unit comes on, once the outside unit comes on it take time for it to cool the coils which cool the house, And a/c does not really cool the air,It removes the heat that is in the air.
    Aug 04, 2010 | Kenmore Heating & Cooling
    A/c unit just blows cool air not cold air at the high range
    mcdevito75 here, have your local a/c shop check it out they come to the house. You can check to make sure you have the unit on cool and that the filter is clean. Unit could use serviceing if not done in 2 years, specific cleaning and a charge of freon gas.
    Jun 22, 2010 | Panasonic CW-C141NU Air Conditioner
    I have an '06 model combination cooling and heatin
    For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
    Dec 22, 2009 | Whirlpool Heating & Cooling
    LG Air Conditioner leaks water
    A/c units produce water, unit must be tilted outside so water doesnt come into house.
    Aug 21, 2009 | LG Heat cool Window Air Conditioner
    Not cooling house. Its never worked.
    Check and see if the inside and outside coils are cleaned , if they are , have someone come out and check the freon in the unit it can leak out over a period of time.
    Jul 20, 2009 | Weather King 10PJA2501AH Air Conditioner
    MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
    Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
    Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
    Air conditioning unit not cooling
    the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
    Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
    Heating & Cooling Logo
    99 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
