Question about Xerox Office Equipment & Supplies
FOULT CODE 22-511.00 MEDIA REQIURED FOR JOB NOT AVAILABLE FOR XEROX C-45 PHOTOCOPIER
    President:
  • 2,072 Answers
What that is saying is that somewhere, most likely in a print job, either the paper tray settings or the settings on the driver are incorrect.
What you need to do is look at the machine paper tray settings and see if they all say the proper size and paper type, and that they match the driver settings.
An example. See that the letter tray settings are 8 1/2 x11 plain paper on the machine and driver. Be for example that the driver doesnt say plain paper and the machine bond, or recycled, or heavyweight. They MUST match or you will receive that message.
The paper SIZE snd TYPE must match.
Posted on Aug 15, 2008
SOURCE:
Error code 010-327 on my Xerox Workcentre Pro 128 photocopier. How easy is it to change the Fuser unit on it? Does it have to be done a professional photocopier technicien? Please advise
Xerox is famous for not letting parts to amateurs, but here is a site that may help. Had a 5035 for years and changed the fuser lamp. Not that difficult on that model. PARTS for Xerox Brand Copiers
Mar 07, 2018 | Xerox Office Equipment & Supplies
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Feb 19, 2018 | Xerox Office Equipment & Supplies
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
004 error code350
I am afraid that that foult code means that the machine's software has to be reloaded. The only way this can be done is by a qulified xerox tech. It need a laptop with special software to connect to the machine to do the download.
Nov 28, 2013 | Xerox CopyCentre C20 Black and White...
I have error j 7 on my xerox 520 workcentre photocopier
this code is for drum cartridge.replace it with a new one. the life of xerox drum cartridge is low
May 30, 2011 | Xerox Office Equipment & Supplies
Reset Job on Workcentre 24
You need to also clear it from the computer. Open the printer properties on the pc to see if the job is still present. If so, cancel it.
Apr 07, 2009 | Xerox WorkCentre M-24 Color Copier
XEROX 3535 FAULT CODE 010-350
foult code 010-348 pleas solve this problem
Apr 04, 2009 | Xerox DocuColor 3535 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
Open Questions:
160 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
