Question about Franklin Machine Products Saws
I have a Franklin macj=hine products bandsaw product YWH-140. One of the trunnions for the table is roken and I am looking for a replacement. Any dealers who these parts in Canada or the USA. Allen
  • 710 Answers
Hi Allen,
Here is contact information for a company in Ontario that sells Franklin products. I would email them and ask where to get parts for your bandsaw near you.
Vision Parts & Accessories Inc.
  • 150 Shields Court
  • Markham, Ontario L3R 9T5
  • Tel: 905.479-3677
  • Fax: 905.472-2516
  • E-mail: sales@visionparts.com
Good luck.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie, "woodworker by night"
Posted on May 22, 2011
Need to replace trunnions under bandsaw table (14inch craftmaster)
I have a band saw parts supplier and they have good deals. But they don't trunnions. I suggest you try to check with amazon.
Mar 18, 2013 | Saws
The trunnion is broken
Try checking with ebay or amazon. I purchase aftermarket band saw parts and I have a supplier . Unfortunately, they don't have trunnion.
Mar 11, 2013 | Craftsman Saws
Boken trunnion 69178
I used JB weld and a 4" piece of 3/4 X 3/4 x 1/8 aluminum angle .I used the JB weld to weld the broken tabs back on.Make sure it is clean and the paint removed.I used a wire wheel on the grinder.I set it on a piece of wax paper to keep in flat. Once that had set up, I sanded it smooth and then used the JD weld to secure the angle over the tabs and up the side. After that set up I used 1/8" pop rivets to reinforce the angle to the trunnion.You will have to shim the other tab when you rebolt the trunnion to the table. seems to work like a champ and cheaper than buying a new band saw.
Feb 06, 2013 | Cars & Trucks
Red light says control locked i cant start macj hine
Hi
Thanks for using FixYa. To resolve this issue and to unlock the controls you'll need to press and hold the END OF CYCLE button for 10-15 seconds. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a craftsman table saw model 137.248830 and the blade is out of square with the miter. How do I adjust it?
You should have 4 bolts holding the trunnion on to the table, just loosen these bolts up a little, tap the trunnion with a hammer, the right way, put a straightedge on the blade fully extended and measure across the table to a dado slot, front and rear, tap it till it is exact, tighten bolts and check again. This should do it. You can check your fence the same way. hope this helps.
Jul 26, 2010 | Craftsman 10" Table Saw
The blade isnot square with table
You can adjust the trunnion assembly from the bottom side of the table. Most saws have 6 bolts that bolt to bottom of top. if you loosen all six bolts then shift as nessessary to align to top top, then retighten the bolts. The holes in the trunnion assembly brackets should be oblong to allow this ajustment, Jim
Jan 23, 2010 | Craftsman 10" Table Saw
HP OfficeJet 7110xi
finally you can try a reset on the macj\hine using the # and the number 6 buttons(holding them down and then plugging in the power cord at the back of the machine).If it still gives the same error..try the same with the # and 9...same problem comes up....service the printer
Jun 24, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Saws Logo
Top Franklin Machine Products Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Franklin Machine Products Saw Expert? Answer questions, earn points and help others
