Question about RCA R52WM24 52" HDTV Projection Television
Color distoted on tv - RCA R52WM24 52" HDTV Projection Television
  • RCA Master
  • 8,617 Answers
That can be caused by either the FL231 fuse or the Convergence power board. www.tvrepairworld.com will assist you in determining which is the cause of the problem if you leave them a email.
Posted on May 24, 2011
Sound distotion
replace tv mainboard
Jan 21, 2013 | Philips Televison & Video
Printing quality is poor. Color has scratch and dirty. Color distotion
Printing Quality of Printer is Poor due to some reason...
* the toner has low level of ink material...
* some problem in the toner pad,,,
* scratch are due to above two reasons and the problem in Roller of the printer....
Aug 16, 2010 | Lexmark C522n Laser Printer
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
The color just went out on my tv - it is only showing in black and white. Is there anything I can do?
There's a few things you can try - change the source or how the source is hooked up. If you are hooked to satelite or cable box (source) try hooking hooking up to the tv (video 1or2 input) with video cables (RCA type -red.wht, Yel) from your source. Also try seeing if you have color when you play a DVD (if available).If it doesn't matter which source you use or how you hook it up you still have no color than the problem is internal to the TV.
These sets have a common problem with an internal comb filter circuit that can cause no color - but it usually also causes distotion in the oicture as well
Hope this helped, be sure to rate/vote for me if it did
Nov 26, 2009 | Hitachi 61SBX59B 61" Rear Projection...
TV has distortion very small on top and bottom which will flicker
This tv has two common problems:
in the power supply (set does distotions and shakes a lot etc very unstable until the set cannot work at all).
powerfully color gets back with a deep clean in the reflexion area. I'm sorry this job is for a technician, The set is so intricate for those two problems that any bad movement in this precision job could send the tv straight to wherever is bad.
Apr 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The color is distoted light is dark and dark is light
Have you tried updating/reinstalling the driver for the video card ? If that's windows then you would have an Application Recovery wizard option to update reinstall the drivers. Open ALL PROGRAMS > open HELP & TOOLS > open Application Recovery . Other operating systems may have something similar. This may be dependent on how old the system is too as to how easy it is to find or if it exists. You may be able also to go to Acer website put in the info model etc and download driver updates from there.
Nov 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Colour distortion
Your screen mask may have become magnetized. This will require that you have the CRT degaussed. This is done with the use of a degaussing coil. you have to stand about 10 feet from the TV with the coil held vertically and moving it in a circular pattern as you walk towards the tv. Once you are about 1-2 inches from the TV stop and continue the circular pattern for about a three count then backup from the tv still using the circular motion once you are about 10 feet from the tv turn the coil to a horizontal plane and move it away quickly and turn it off. This should degauss the TV and remove the color distortion.
You will need a degaussing coil to perform this task.
Thank you,
Shuttle83
Nov 27, 2007 | Televison & Video
Distoted video
change the head it is bad good luck.
Apr 17, 2007 | Tivo TCD540080 80-Hours Video Recorder
RCA R52WM24 52" HDTV Projection Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
