Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
It doees not print accurately.....lines tend to be crooked in places. The screen says that there is paper jammed in the machine but I can't see any stuck in the machine and I am not aware of any paper being torn during priting. Maggie Joyce
    Scholar:
  • 56 Answers
Usually its on the rollers ...Try to clean the rollers with just clean paper .remove the cartridgs. clean also the contacts and the place where the ink goes out on the cartridge
make sure Its clean clean also the area where you put it in the cartridge carrier
And in case nothing happens try to update the driver . CHeck the stylus model just type it in the search box of the Epson.com and you will seethe drivers
Hope it helped thanks
In
Posted on May 22, 2011
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
Canon MX320 crooked printing
They are correct. Inkjets are almost never worth fixing, the parts are to costly. Get a laser jet you will save yourself a lot of grief.
Jul 09, 2012 | Canon PIXMA MX320 Color USB InkJet Printer
Error C000!! what can i do it wont print,
  • Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
  • If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
  • Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Sep 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I can't print anything as the paper feeds in crooked and jams
Perhaps there is still a bit of paper stuck in the machine from a previos jam? Follow the manual to clear a paper jam. Then "fan" your paper like a deck of cards before placing it in the feeder. Make sure the paper guide is not set too tightly causing the paper to not lay flat as it enters the printer.
Dec 05, 2009 | HP Office Equipment & Supplies
Skewed or crooked paper uptake on Canon Pixma Mx300
Sounds like the roller(s) on the left side is missing or is slick (or split). You should have returned it to the place of purchase when you discovered the problem.
Jul 09, 2009 | Canon PIXMA MP470 All-in-One Printer
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
E3 paper jam
if the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Apr 21, 2008 | Office Equipment & Supplies
Brother IntelliFAX 2800 - Paper Jam
It could be one of two things. First and most common is one of the sensors is dirty/stuck and a quick round of compressed air will usually take care of it. This is especially common if you have been running 3 hole punched paper as the loose punches tend to cover sensors. Recycled paper also tends to leave some dusty residue and that will, in time, obscure the sensors, along with a dusty environment or if the machine is on the floor. Another possibility is one of the physical sensors got knocked off course a bit. This could be caused by pulling out jammed paper too roughly or running lots of heavy paper through the unit. I would do a visual inspection for any bent or crooked parts.
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
