Lamp monitor system all indicators stay flashing
  • 27,725 Answers
Test the PSU if the units fan is not working the power supply unit is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket hope this helps
Posted on May 22, 2011
MY AIR BAG LIGHT IS STAYING ON AND SOMETIMES IT FLASHES?
You need to find out what the fault code is. It will direct you to the area responsible.
Air Bag Diagnostic Monitor
ani_caut.gif WARNING: UNDER NO CIRCUMSTANCES SUBSTITUTE ANOTHER FUSE VALUE FOR THE 10A BATTERY FUSE. ANY FUSE OTHER THAN 10A MAY CAUSE DISARMING FAILURE AND MAY RESULT IN DANGER TO THE OCCUPANTS OF THE VEHICLE. DO NOT ATTEMPT TO REPLACE THE 10A BATTERY FUSE UNTIL THE AIR BAG SYSTEM FIRST HAS BEEN DEACTIVATED (SEE DEACTIVATION PROCEDURE FOR DETAILS).
NOTE: The safing sensor is internal to the air bag diagnostic monitor (14B056) and is not replaced separately.
The air bag diagnostic monitor continually monitors all supplemental air bag restraint system (SRS) components and wiring connections for possible faults in the system. If the air bag diagnostic monitor detects a fault in the SRS when the ignition switch (11572) is in the RUN position, a diagnostic trouble code (DTC) will be displayed by the air bag indicator, located on the instrument cluster (10849).
The air bag diagnostic monitor does not deploy the air bag in the event of a collision. The LH or RH air bag sensor and the safing sensor determine when to deploy the air bag.
The air bag diagnostic monitor illuminates the air bag indicator for approximately six seconds when the ignition switch is in the RUN position and then turns the indicator off. This shows that the air bag indicator is operational. If the air bag indicator does not illuminate or the indicator stays on or flashes at any time, a fault has been detected by the air bag diagnostic monitor.
DTCs may not be displayed for approximately 30 seconds after the ignition switch is placed in the RUN position. This is the amount of time the air bag diagnostic monitor requires to perform all tests and verify system faults.
Each DTC (a series of flashes and pauses of the air bag indicator):
  • Represents a two-digit number.
  • Is always displayed at least twice.
If the diagnostic monitor detects a fault in the air bag system, a DTC will be written to the diagnostic monitors non-volatile RAM (NVRAM). This DTC will then cause the lamp to flash a lamp fault code (LFC) on the air bag indicator and can be retrieved with the New Generation STAR (NGS) Tester. After repair, the DTC may then be cleared from the NVRAM.
If a system fault is present and the air bag indicator is malfunctioning, an audible tone will be heard. The tone is a series of five sets of five beeps. If the tone is heard, the air bag system requires repair.
If a fault exists that makes unwanted air bag deployment possible, the air bag diagnostic monitor will attempt to remove deployment power by turning on a solid state switch to blow the 10A battery fuse 2.
If the 10A battery fuse has successfully been blown by the air bag diagnostic monitor, the air bag diagnostic monitor will not attempt to blow it again until the proper fault has been repaired and cleared (see Diagnostic Trouble Code Clearing procedures for details). The air bag diagnostic monitor will store both the unwanted deployment DTC and the loss of deployment power DTC. The loss of deployment power DTC is the highest priority.
DTCs are prioritized numerically. If two or more faults occur at the same time, the fault having the highest priority will be displayed first. After that fault has been corrected, the next highest priority fault will be displayed.
The air bag diagnostic monitor includes an internal backup power supply. This feature provides sufficient backup power to deploy the air bag in the event the battery (10655) or battery cables are damaged in a collision before safing and air bag sensors close. The backup power supply will deplete its stored energy approximately one minute after the positive battery cable is disconnected.
The DTCs can be retrieved with New Generation STAR (NGS) Tester using the Retrieve/Clear Continuous DTCs option. Any DTCs stored in the air bag diagnostic monitor will be displayed on the NGS along with a brief description of the DTC. If no DTCs are present, the NGS Tester will display a SYSTEM PASSED message. This option can also be used to clear DTCs from the air bag diagnostic monitor memory, as long as the concern no longer exists. Once a DTC is logged into the air bag diagnostic monitor memory, it will stay in memory until 255 key cycles have been recorded or until the NGS is used to erase the DTCs. Once 256 key cycles have been recorded since the concern was last detected, the DTC will automatically be removed from memory.
Jan 18, 2011 | 1997 Ford Expedition
Screen is black
If the notebook appears to boot up and the LED hard disk light flashes then :-
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 13, 2009 | Acer Aspire 5100 Notebook
Unite powers up, but screen stays dark. Unite is 11 months old, and used daily.
www.ladparts.net
Dec 08, 2009 | Acer Aspire 5610 Notebook
Power stays on but screen goes black on my Gateway laptop.
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Nov 22, 2009 | Gateway 450ROG Notebook
My Dell flat panel monitor flashes on and off what can i do to fix it...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 14, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Monitor blacks out
Check out
www.lcdparts.net
Sep 12, 2009 | E-Machines eMachines Monitor E15T4
Computer is on, screen stays black
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 04, 2009 | Acer Aspire 3690-2196 Notebook
Airbag light on. flashing 5 times 2 times then stays on
I think you have a false code stored due to your work. clear the code and you should be ok.
Diagnostic trouble codes (DTCs) may not be displayed for approximately 30 seconds after the ignition switch is placed in the RUN position. This is the amount of time the air bag diagnostic monitor requires to perform all tests and verify system faults.
If the diagnostic monitor detects a fault in the air bag system, a diagnostic trouble code (DTC) will be written to the diagnostic monitor's Non-Volatile RAM (NVRAM). This DTC will then cause the lamp to flash a lamp fault code (LFC) on the air bag warning lamp and can be retrieved with the New Generation STAR (NGS) tester. After servicing the DTC may then be cleared from the NVRAM.
If a system fault is present and the air bag indicator is malfunctioning, an audible tone will be heard. The tone is a series of five sets of five beeps. If the tone is heard, the air bag system needs attention.
If a fault exists that makes unwanted air bag deployment possible, the air bag diagnostic monitor will attempt to remove deployment power by turning on a solid state switch to blow the 10A battery fuse.
If the 10A battery fuse has successfully been blown by the air bag diagnostic monitor, the air bag diagnostic monitor will not attempt to blow it again until the proper fault has been repaired and cleared (refer to Diagnostic Instructions). The air bag diagnostic monitor will store both the unwanted deployment diagnostic trouble code and the loss of deployment power diagnostic trouble code. The loss of deployment power diagnostic trouble code is the highest priority.
If a fault exists that makes unwanted air bag deployment possible, the air bag diagnostic monitor has an internal fuse that that will blow (open) automatically. This removes all power to the air bag deployment circuit.
Once a DTC is logged into the air bag diagnostic monitor memory, it will stay in memory until 80 key cycles have been recorded or until the NGS is used to erase the DTCs. Once 256 key cycles have been recorded since the concern was last detected, the DTC will automatically be removed from memory.
Active Command Modes
This command allows the technician to verify operation of the air bag system, indicator and tone. When the air bag output command is executed, the indicator and the tone are simultaneously activated for approximately four seconds. Both devices are automatically deactivated.
Air Bag Diagnostic Monitor DTC Priority Table DTC LFC Description Action To Take B1342 24 Air bag diagnostic monitor is faulted (retrieved only during On-Demand Self Test) GO to Pinpoint Test P . B1867 12/52 Lost or low battery voltage GO to Pinpoint Test A . B1869 — No air bag indicator — inoperative indicator circuit GO to Pinpoint Test R . B1913 13/53 Air bag circuit shorted to ground — driver/passenger GO to Pinpoint Test B . B1914 14/54 Air bag sensor circuit shorted to ground GO to Pinpoint Test C . B1921 21 Air bag diagnostic monitor ground circuit open or not mounted to the vehicle properly GO to Pinpoint Test D . B1922 22 Safing sensor output circuit shorted to battery voltage GO to Pinpoint Test E . B1924 24 System disarm fault GO to Pinpoint Test P . B1932 32 Driver side air bag module circuit high resistance or open GO to Pinpoint Test F . B1933 33 Passenger side air bag module circuit high resistance or open GO to Pinpoint Test G . B1934 34 Driver side air bag module circuit low resistance or shorted GO to Pinpoint Test H . B1935 35 Passenger side air bag module circuit low resistance or shorted GO to Pinpoint Test J . B1941 41 RH air bag sensor feed/return circuit open GO to Pinpoint Test K . B1942 42 LH air bag sensor feed/return circuit open GO to Pinpoint Test L . B1944 44 RH air bag sensor not mounted to the vehicle properly or ground circuit open GO to Pinpoint Test M . B1945 45 LH air bag sensor not mounted to the vehicle properly or ground circuit open GO to Pinpoint Test N .
DTC - Diagnostic Trouble Code, retrieved using New Generation STAR (NGS) Tester.
LFC - Lamp Fault Code, flashed on air bag indicator.
May 21, 2009 | 1997 Ford F150 Regular Cab
Ihave an acer 9410Z laptop the backlight won't
Check out
www.lcdparts.net
Mar 11, 2009 | Acer Aspire 3000 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
