Question about Mitsubishi WD-57733 57" HDTV
HDMI Inputs don't work (and I've tested my components with another TV). When viewing on Component 1 input, the picture has blotchy color, like water colors. Adjusting color and brightness doesn't help. The tint control has no effect, and in fact, the tint slide looks funny on screen. The audio control no longer allows selection of the A/V external. The only setting it allows now is TV. Reset does not change the symptoms.
  • 3 more comments
  • Norman Birt May 22, 2011
    Thanks for the suggestions. Do you know where I can get a schematic and component layout without spending a bunch of money? I do have electronics experience, so swapping components and replacing bad capacitors is no problem. This problem did occur right after we had a severe thunder storm and a power outage. I have the TV hooked up to a surge protector, and it was off at the time, but I guess it's possible that it still took a hit.
    Can you get me started by pointing me to the Color Oscillator location?
    Thanks,
    Norm
  • Norman Birt May 25, 2011
    Tried reset as suggested by jdvillanueva, problem still there.
    I am purchasing a parts and service manual to help me, but would appreciate further guidance.
    I have opened the TV, and inspected the power supply. I don't see any physical issues with respect to capacitors or other components as recommended by the other expert.
    Looking forward to your help.
    Norm
  • Norman Birt May 26, 2011
    Thanks,
    It's ok, I have the manual already. I have an o-scope and multi-meter. I've been looking at the schematics and block diagram. Seems that maybe the commonality between all the symptoms may be the Xilleron Core (IC 8001), or the Digital Video Converter (IC 7G00). I'm guessing of course, since I have problems with both the HDMI and AV audio out. I sure welcome your guidance though.
    Waiting for your next suggestion,
    Norm
    Hi, I measured voltages as follows: Connector PD Pin 10,11,12 = 12vdc. PD pins 15,16 = 18vdc. FB pin 3 = 5vdc. TA pins 40,42,44 = 5vdc. TA pins 46, 48, 50 = 9vdc. TA pin 52 = 3.3vdc. AN pin 3 = 3.3vdc. AN pin 5 = 5vdc. C8081 plus side = 1.8vdc. C8091 plus side = 2.6vdc. C8004 plus side = 1.2vdc. I think that covers all the voltages we're concerned about. I inspected the main board top side, and don't see any damage or suspicious looking parts. I'm ready for the next step. Thanks, Norm
  • Norman Birt May 27, 2011
    Hi, I did get 9vdc on TA pins 46, 48 and 50. Maybe I forgot to send you that input. So, since I have these voltages, what next?
  • Mitsubishi Master
  • 2,098 Answers
First lets re-initialize the AV Memories by following the steps below.
Press the front panel "Guide" and "Format" key at the same time.
Wait until the unit reboot and then try if the symptoms still there to guide you further.
Jdvillanueva
Posted on May 23, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva May 26, 2011
    Thanks for the response.
    Don't buy online for the copy of the service manual, I have a copy. Please let me know your email add and I will send it to you for free. If your handy with electronics and have necessary tools and test instrument, I will guide you fixing it yourself after you've got the copy of the service manual.
  • Jdvillanueva
    This kind of trouble has a 50% chance fault from power supply and 50% chance fault from the parts you've mentioned.
    Let's isolate first the power supply from fault. Missing supply voltage will disable the IC's. On page 70 of the service manual shows there the supply voltage (3.3v, 2.5v, 1.8v, 1.2v) and almost same voltage on page 78. Check this voltage if present.
  • Jdvillanueva
    Jdvillanueva May 27, 2011
    Hi, nice reading but it seems your missing the 9v on TA(pin# 46,48,50). Please re-checked this voltage. On page 61 it is a supply to the IC2J01 which is also linked to IC7A01 which is processes the inputs...
    President:
  • 2,187 Answers
The problem may be with the color oscillator of the circuit. Check first for swollen or leaking capacitors. Capacitors are cylindrical in shape and is black in color (color may vary) and has two legs soldered to the board. It may also be a faulty board based on the number of items damaged. You would have to need special tools to have this fixed or replace the board depending on the practicality.
Posted on May 22, 2011
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hdmi input not working
Video is different from HDMI. From what I have seen you should have video inputs and component inputs. instead of trying these video inputs, look for tv/component button on your remote or tv settings.
Feb 01, 2014 | Toshiba Regza 52XV645U LCD TV
Our HDMI 1, 2, & 3 jacks do not work any longer. It's not the HDMI cord (replaced already) it's not the dish network box (replaced it today) - it's the TV. Can we fix it ourselves? Sanyo...
There is no "fix" for defective jacks for the average consumer like that.
I suggest using the COMPONENT inputs instead. Sorry, that means another new set of wires.
Component input will still be HD, it's just a lot more wires than the simple "one wire" HDMI.
At least you don't have to trash (or get repairs) to your TV and it will hold you over until you do.
Take care!
Sep 11, 2011 | Sanyo DP50747 50 in. Plasma TV
I have a toshiba tv and a sony dvd player and i want to know how to install the jacks and if i need the hdmi cord
It really all depends on what else you may have hooked up and, what inputs you have on your TV. If you have an open HDMI in on your TV, I would use that because you will get your sound and vidoe with one cable(HDMI). If you don not have an open HDMI port on your TV, component cables are the your next best option video wise. The component cables do not carry sound so, you would have to get your sound by using,(best) digital optical or RCA. After looking at your player, your best picture would be using component and, it says it has SPIDF out but doesn't exactly specify what kind but, if you don't have the component cables, use youe RCA jacks(yellow), video out, and red and white(left and right audio) out from player to suitable input on TV. If I looked at the right player, there is no HDMI out on it.
Jul 02, 2011 | Sony DVP-SR200P DVD Player
No component video with my Wii (component audio and HDMI video/audio both fine). It used to work fine, but now it won't show any picture regardless of which component IN I use. I checked all assigned...
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
May 11, 2017 | Onkyo TX-SR606 Receiver
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
My hd tv
to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Greenish tint
First of all component inputs are analog as the only digital inputs are the DVI or HDMI inputs on a TV. You might have color adjutments in the menus somewhere that allow you to compensate for color weakness on one or more colors. If not you most likely have a bad digital board.
Apr 07, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Mitsubishi WD-57733 57" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
