Question about True GDM-37 Refrigerator
The compressor is running & warm to hot which is normal & both fan are working but not cooling
dididsaythat
  • 291 Answers
SOURCE: frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Posted on Sep 12, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
  • 62 Answers
SOURCE: whirlpool el7atrrkq01 won't cool
First, please re-check to see if both fans are running, the condenser fan by the compressor and the evap fan in the freezer. Next, empty the freezer and remove the evap cover. look at the evap coils. Are they completly frosted up -- if so, you have a defrost problem - this will cause the condition you describe- IF they are not frosted, are only a few of the passes of coil frosted and some just wet with no frost? Then that means you need some freon. The fact that you have some cooling means that the compressor is probabaly OK.
Posted on Sep 01, 2008
docjohn174
  • 943 Answers
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: Fan works, just stopped cooling TRUE GDM 26
there is a leak of gas in the system,must see where the leak is, repair it then fill the gas,
Posted on Aug 21, 2009
Frigidaire refrigerator/freezer side by side not kicking on. Both freezer and refrigerator not cooling.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 03, 2012 | Frigidaire Refrigerators
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
My side side frige is warm to the touch in the middle
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range is important to keep those temperatures lower in the yoder loop. If helpful please rate this solution, Thanks Sea Breeze
Jun 28, 2011 | Kenmore 53642 / 53644 Side by Side...
Hi my botton frezer no working the compressor its hot
Compressors are normally 100-120 degrees when being cooled by a condenser fan motor. If there is no fan motor near the compressor then it can run up to 180 degrees, so the compressor temp by itself doesnt mean much. You can take an ampmeter and clamp it around one of the wires to the compressor to see if it is running, drawing anywhere from 1-2.5 amps or trying to start, in which case it may draw up to 20 amps every 3-5 minutes.
Oct 05, 2010 | Amana ARB8057CSL Bottom Freezer...
In between doors on side by side fridge is hot. Whirlpool GD5phax
you need to fix the fan down by compressor as it cools the cond coils and causes proper orp of cmpressor . if it not running the comp runs too hot and does not pump the refergent and may be shutting of on overload . the high tempt between the doors will be less with fan working . but some warm tempt is normal .. mm
Jul 29, 2010 | Whirlpool GD5SHAX Side by Side...
Refer warming / no compressor / no fan
If the fan doesn't work , the compressor overheats and shut off by the overload protection.I would replace the fan which will cost no more than $30.
Sep 19, 2009 | Refrigerators
Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Aug 14, 2009 | Heating & Cooling
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
1999 Amana BB20/BRS20 refrigerator not cooling
Take the back cardboard panel off of the back and feel if the compressor is hot. alsocheck to see if the condensor fan is running. if the fan is inop, change it. If the compressor is hot, find a clamp on amp probe and clamp it on one of the wires going to the compressor.If the reading is over 5, you have a bad compressor. You may be able to get by with a RCO410 three in one hardstart.
Dec 08, 2007 | Refrigerators
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
True GDM-37 Refrigerator Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
