Question about Encore 56K V92 USB External Data Fax TAM Modem (569286)
I bought a splitter for the phone line to connect the fax and phone to the wall jack so one line goes to the phone and one line is connected to a encore v.92/56k modem. The splitter has L1 and L2 to connect to. The L1 will work but the L2 will not. I have a direct line from the wall jack to an Comcast modem with the splitter into that phone jack. One line goes to the phone and the other to the fax modem. Again only the device plugged into the L1 will work. Is there a solution for this?
  • 1894 Answers
SOURCE: Modem Driver
http://driver.wareseeker.com/Modem/smartlink-90-92-internal-modem-driver-4.20.01.zip/322920
tis s tthe link for downloading the driver
Posted on Dec 27, 2007
  • 6 Answers
SOURCE: encore modem
As far as I've seen, the data line light on the modem should indicate whether the data signal is coming through from AT&T or not, so I'd suspect that there is a problem with the signal from AT&T rather than between your modem and computer.
It is possible that the data signal lapsed for a while and your modem thinks it's still not there without actually looking. You can try unplugging your modem from it's power for about a minute (at least 30 seconds) and then replugging it in afterwards. That sometimes allows it to see the new data signal if it lapsed previously for any reason. After all lights light up (especially the data one), then try to go online again. If that doesn't work, try restarting the computer and if that doesn't work I'd try to talk to someone higher up in the AT&T support and explain about the data signal not showing on the modem so you can get them to fix it.
Hope that helps! :)
-Aloha!
Posted on Apr 11, 2008
sadguy
  • 88 Answers
SOURCE: Modem Driver - V.92 56K Modem
http://www.usr.com/support/s-main-menu.asp
go this web side
rate me thx
Posted on Aug 15, 2008
watz up
  • 6 Answers
SOURCE: siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Posted on Sep 19, 2008
  • 96 Answers
SOURCE: Problem with Encore 802.11n Wireless Router ENHWI-N2
Are you able to access internet when you are connected with a cable netween your laptop/desktop and router please check if yes then with the same connection go to http://192.168.1.1 default username admin and password "admin" and then check in the wireless tab is there any security on the wireless the same code needs to be entered on the laptop also in wirless network connections
Or the issue can be conenctivity between your service provider and router you may need to do some settings as per your service provider on the router for that again you need to open the 192.168.. page
let me know if this help, the below link will help you to check your connection once by one
Posted on Dec 01, 2009
Trying to connect fax with my optimum (which is a triple play package) I also have wireless. The Wall jack cord is going directly into the modem. How do I connect the fax?
Your Optimum modem is acting the same as the phone company's input line to your home. The cord that goes from it to the wall jack is actually powering up all wall jacks it the home. You can:
  • Use any available wall jack in the home to cable up to the fax.
  • Split the output signal from the Optimum and connect to the splitter (may not work).
  • Run the Modem output to the LINE connection of the fax, and the EXT output of the fax to the wall jack (may not work)
Jun 28, 2015 | Office Equipment & Supplies
I wish to use one line for both my landline and fax how is this done
Connect the line in the fax (LINE JACK) AND THE landline in the fax jack MARKED AS TEL.
Dec 17, 2012 | HEWLETT-PACKARD HP 2140 Fax
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Fax gets a phone line error. I switched from 1 line to another. I used a single line splitter but it still will not fax. What to do?
Hi, it seems you got a connection problem. Here are some tips to check it:
1. Make sure the phone line in the wall is working. There should be a dial tone if you connect a regular phone device in that.
2. Check if the telephone cable that you're using is in good condition.
3. Telephone cable from the wall/splitter must be plugged in to the Line port behind the printer.
4. Make sure that it's the correct fax number assigned in the printer.
5. If all is ok but still having the error, try plugging the printer/fax straight to the wall jack bypassing the splitter.
Hope this helps.
Mar 06, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Hooking up cables and phone line to use the Fax on the P3150
Find a telephone wall-jack.
Buy a 1-to-2 telephone-splitter -- one end plugs into the wall-jack, and the other end provides 2 telephone-jacks.
Connect your telephone to one of those 2 jacks.
Connect your All-In-One to the other of those 2 jacks.
Be sure to use a 4-wire telephone-cable, not an 8-wire network-cable.
Feb 03, 2010 | Lexmark P3150 All-In-One InkJet Printer
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
Faxing with Dell printer 968
Firstly yes your telephone number is used as your Fax number.
Your phone line connections sound ok, so the problem must be with your fax machine.If it's a combined Fax/Printer make sure you select Fax mode.
Dec 05, 2008 | Office Equipment & Supplies
I can't receive and send fax
The splitter the technician is referring to goes on the wall jack. One should have come with the "modem" installation package.
Take a regular telephone cord and plug one end into the splitter and the other into the line jack on the Fax/printer.
When your done you should have two phone cords connected to the splitter - one going to the "modem" and the other to the printer.
Nov 11, 2007 | Office Equipment & Supplies
Encore 56K V92 USB External Data  Fax  TAM Modem (569286) Logo
42 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
