Question about Brother MFC-7820N Printer
Stripe on receiving fax Brother MFC 7820N
I've been told that everything I fax has a black stripe straight down the middle when received. This isn't happeining on the faxes I receive, just the ones I've sent. I have cleaned the corona wire, wiped the scanner, and blown out any dust. Is there somewhere else I can wipe/clean/adjust to eliminate this?
  • 3 more comments
  • dgdiaz Aug 15, 2008
    Dear IFIXU2:
    I made the copy and it is clear....So no problem with my scanner?? Is there anything else that could cause sent faxes to print with a big black stripe when received?
    Thank you!
  • longfieldcar Feb 02, 2009
    We also have a black stripe when using faxes but not when copying> How do we resolve please
  • lillybell3 Feb 07, 2009
    I have the same problem with mine since I purchased it. Copies are fine, no black line but when I use the feeder to fax things, the black line shows up. I usually have to fax things without using the automatic feeder which takes forever to do because have to scan each page, otherwise the black line will show up in all the faxed pages. Same thing with copies. If I make a copy using the scanner it is fine but when I feed it through the automatic feeder to make copies, all copies come out with the black line. I think for mine, it must have something on the glass of automatic feeder portion causing this. Never have been able to fix it.
  • shadishakra Feb 18, 2009
    I have been having the same problem for the past year... anyone have a solution that works?
  • Anonymous Mar 30, 2009
    Had the same problem for forever and just fixed it because of a helpful comment from shadishakra. There was a spec of dirt on the glass in the scanning area. Just cleaned it and no more stripe!! Boy do I feel dumb; I guess I should have cleaned it sooner... Note that there are two areas for scanning with this machine. One smaller glass area to the left which is used when paper is fed via the feeder, and the other, large area of the flatbed. Clean both areas, but anything showing up when feeding is due to the small area. Thanks!!
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Posted on Feb 18, 2009
  • Dorothy Mowat Mar 26, 2013
    Thank you for posting this! The solution had been staring at me every time I lifted the lid! On the very left-hand side is a 3 step explanation of how to fix this, by cleaning the glass strip right on the edge. So simple really, and how blind am I. If you hadn't posted this comment, I would never have noticed this..
One Small dot of may be ink or some dust stuck on the glass.
Cleaned the glass with windex and scanning, coping like new.
Thanks Fixya.
Posted on Nov 01, 2011
    Novelist:
  • 158 Answers
Use the COPY mode on your fax machine to scan an original with only a small number of words on it. If the COPY made on YOUR fax machine has the black line on it, YOUR SCANNER is definitely the cause, and there is probably ink or correction fluid on your scanner glass, or possibly dirt UNDER the glass. The mark on the scanner may be only a tiny dot, but since the original is moving, it scans as a line, so look closely for ANYTHING on the scanner.
Posted on Aug 15, 2008
  • Phil Oellrich Aug 16, 2008
    Does the black line appear on faxes sent to any machine or only one? If it is happening on faxes you send to different machines, and its not your scanner, the black line may be caused by one of the circuit boards in your fax. Try unplugging your fax from the phone line, and the AC power outlet. Wait 30 seconds and reconnect and turn on. Send a test fax to another fax machine . If the line is still there, try a RAM or MEMORY CLEAR to try to reset your machine. Be sure to printout ALL LISTS (speed dial, settings,etc.) BEFORE you clear any memory. All data will be erased, and your fax will be restored to factory settings.
I have had the same problem with my 7820N since I first got it. My problem is more persistant than yours, as anything I scan (fax, copy or scan to PC) has the black line down the middle. Receiving or printing is fine, so I know its the scanner. I had brought it to a service center when it was only a month old, and after having it for 1 week, I get it back and turn it on, it sees to be fixed! Then I copy something 10 minutes later and the black line is back.
I didnt have time to bring it back for service, so I lived with it. The odd thing that I realized is that if I turn the printer off for a period of time of say 10 min or more, and scan...there is no line. Then after the printer being on for about 5-10min the line is back. Seems like when it warms up? I dunno. Just thought I would share my story. I use another fax to send faxes and if I'm really desperate to scan something, I'll turn it off for a little while, then turn it on and scan real quick.
Posted on Sep 11, 2008
How do i print the fax that is in memory on my brother fax machine
Posted on Sep 10, 2008
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
I am getting a light duplication on my copies half
The duplication problem can be either the drum or the fuser. Most likely your drum needs to be replaced. If you can measure the distance between the first print and its duplicate I might be able to help more.
thanks adi
Dec 15, 2009 | Brother MFC-7420 Printer
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Dec 13, 2008 | Brother MFC-7820N Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
1,023 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
