The LCD is fading and if you run your finger across the surface you can make portions appear.
    Problem Solver:
  • 12 Answers
The LCD display needs to be replaced. The unit may be available on EBay.
Posted on May 22, 2011
Printing fades on the page
Does it fade across or down?
Is the printer on a level surface? (important!)
or
Take toner cart out and shake it side to side gently, replace it. Is it any better? (yes indicates low toner)
You may just need a new toner cart or drum
http://printer.konicaminolta.net/drivers/manuals/2300dl/eg_user.pdf
Jul 30, 2014 | Konica Minolta Magicolor Office Equipment...
How to remove a green line appearing near the taskbar portion of my laptop
A. Please try this: Please start, in the search box type msconfig and hit enter on the keyboard. You will get System configuration utility. Please click tab, startup and then click Disable and then click OK. Restart your computer.
B. To remove malware/adware/spyware:
Please scan your computer using free version of Superantispyware.
http://www.superantispyware.com/
Please run quick scan.
Jun 01, 2013 | Dell Inspiron Computers & Internet
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Blue line across bottom of screen on a Sony LCD rear projection
Contacted Sony Eletronics and was told it could not be fixed . Sony
offered a great deal to trade in for a much better one : a 55" Sony Bravia valued at $ 2,000 for $ 825 . Not bad !
Feb 05, 2010 | Sony KDF-E42A10 42 in. LCD Television
Samsung LCD TV faded area
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 09, 2017 | Samsung Televison & Video
Faded section of screen
Is it an LCD or plasma monitor? If it's an LCD, it's possible that one of the fluorescent backlight tubes is bad. In some early ones, this is bonded to the LCD panel so it's not replaceable. Maybe it's under warranty?
Jul 18, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Line across screen
go in to the bios if the line still exist in the bios then your lcd needs to be replaced.
If the line goes away then you need to re-install your video driver
Apr 11, 2009 | Computers & Internet
Nikkor Lens Fix
The fading (flare) you see could simply be a finger smudge or other stuff. One little scratch won't do it, you'd have to take sandpaper to the lens to see obvious flare.
It's actually harder to scratch a modern lens than most people think. When it happens, it's usually during cleaning when a tiny piece of grit is on the surface and gets rubbed in by the cleaning cloth/lens tissue.
So the first step in cleaning a lens surface is to be sure you remove all dust and dirt without rubbing. The lens cleaning kit you can find in any camera store is a start -- it contains a blower brush. With the lens surface to be cleaned facing down (so dust falls away), brush gently with the tips of the bristles to dislodge stuff. Then use the blower to blow it away. Repeat as needed.
If you still see dust and dirt which seems to be stuck on the surface, take a piece of the lens tissue from the kit and put several drops of the cleaning solution on it, enough to get it pretty damp. (Always apply cleaning solution to the tissue or cloth, never drop directly on the lens surface.) Cover the lens surface with the damp tissue, pressing it into the corners, but do not slide the tissue across the surface. Just lift it away. Repeat with another section of tissue.
Then take a full sheet, wad it lightly, and wet it. You are going to rub lightly, using a roll-up motion as you move the tissue so that dust/dirt is lifted away from the surface and fresh tissue is always coming in contact with the surface. Repeat as needed until there isn't any visible stuff.
Final cleaning can be done with a fresh piece of tissue and a bit of mist from your breath. Mist the surface, and lightly polish with the tissue to remove any remaining cleaner residue.
Dec 08, 2008 | Nikon Normal AF Nikkor 50mm f/1.8D...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
