Question about GE Microwave Ovens
Is there a way to correct a keypad short on a wes1450 GE
  • GE Master
  • 9,047 Answers
No, sadly the WES series ovens were made for the rock bottom market, and GE does not make any parts available for them except the turntable and turntable support.
If it's under warranty, you can return it to Walmart.
If not, it's off to the dump.
Sorry to bear bad news.
Posted on May 25, 2011
My ge is Microwave beeping and says keypad short may need service
PCM/Smart board (comes with the keypad), If it is less that 30 days beyound the 12 month warranty call GE and ask for a "good will concession" ... 1800-GECARES
Apr 28, 2014 | GE XL1800 1100 Watts Microwave Oven
Ge wes1450
You have to remove the outer enclosure to gain access to the lamp. read and heed the warnings about high voltages before poking around inside.
Mar 01, 2014 | Microwave Ovens
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
What does the F3 alert indicate for a GE JES1238WH001?
F3 is a shorted keypad. Unfortunately you need to replace your touch pad to correct the issue. This can happen sometimes from moisture getting into the keypad from boiling water, or it can happen for no reason at all.
Sorry there is no parts available for the microwave.
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 30, 2010 | GE Microwave Ovens
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
Jul 26, 2010 | GE JVM1850 1000 Watts Microwave Oven
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Heard on news of fires even when off
That's usually form shorted or shorting keypads.
What to look out for is is you get an F3 error on your keypad (assuming you have a GE - the code is different on other brands).
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls or short the keypad.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Or just to be safe, you can just leave the oven's door open at night or actually any time you're not using the oven..
May 24, 2009 | GE Spacemaker JVM1740 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
441 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
