Question about Power Acoustik Car Audio & Video
I need to know what the power is on a cr800 2x Poweracoustik amp when it is bridged...
  • 3,018 Answers
  • You double the watts to the speaker for the channels bridged. This also depends on the Ohms of the speakers being used. The lower the Ohms of the speakers used in relation to the Ohms of the amp also increases the watt output of the amp.
Regards, Tony
Posted on May 22, 2011
How do I bridge a power acoustik ov4 - 840 in bridged node
Google your model number or go to www.poweracoustik.com and download the owners manual. You can bridge it to 2 channels 4 ohm stable only!
Sep 02, 2016 | Power Acoustik Car Audio & Video
Need a installation manual
Here is a link to Power Acoustik support page:http://www.poweracoustik.com/pa2006/OWNER_MANUAL.htm#current pd From the Amplifier drop down list, select "Lightning Series 03-07" or let me know your email and ill send you the PDF myself.
dreamsystems
Feb 12, 2011 | Power Acoustik LT-720/4 Car Audio...
Is there a customer service number for Power Acoustik? I am trying to install headrest DVD but one on the output pin connectors has bent pins inside and will not connect to headrest cord. It's defective...
Here's the link for the return authorization form they have you fill out online:
http://www.poweracoustik.com/pa2006/form1.htm
Here's their contact information:
Power Acoustik Electronics
1550 S. Maple Ave. Montebello, CA 90640 USA
Phone: 323-722-3333
Fax: 323-722-1122
http://www.poweracoustik.com/pa2006/CONTACT.htm
Nov 08, 2010 | Power Acoustik HDVD9 Car DVD Player
Can i bridge this hifonics amp
If you don't know if the amp is bridgeable, then I wouldnt do it. It could already be bridged internally and bridgeing it through the speaker terminals could be disatrous, i.e. the infamous blue smoke of death. The amp looks like a 2 channel amp fromt he pic and you have two speakers you are trying to power with it. So the safest bet would be to just unbridge your speakers and hook them each up to the amp as normal. No blue smoke. Good luck!
Feb 18, 2010 | MTX Thunder 801D Car Audio Amplifier
I need a wirning diagram for the Power acoustic 2000 1/D amp
http://www.poweracoustik.com/pa2006/manual%20and%20catalog/4.23%20BAMF%20MANUAL.pdf
THE LINK ABOVE WILL TAKE YOU TO THE SUPPORT PAGE FOR YOUR AMPLIFIER SERIES. IT INCLUDES YOUR AMPLIFIER ALONG WITH THE OTHER SIMILAR MODEL NUMBERS. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Jan 11, 2010 | Power Acoustik BAMF2000/1D Car Amp
I have 2 15 inch mofos do i need two poweracoustik 4000D AMPS?
You want an amplifier that is rated for the subwoofers. In your case your subwoofers are rated at 1500 watts rms each, so you will need an amplifier of 1500 watts rms or more for one subwoofer. good luck
Dec 26, 2009 | Power Acoustik MOFO-15 Car Subwoofer
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
Bridge subwoofers
Without looking up the individual specs of your speaker and amp, I'll offer a few basics when it comes to bridging an amp.
Most important...find out what impedance (ohm) that your amp can handle bridged!! If you go below this rating, you will run the risk and most likely eventually overheat and short circuit the amp. You must also know the impedance of your sub (which can come in a variety) to be able to match them. Depending on this impedance match-up, it may be less beneficial to bridge the speaker to this amp. For example if there is an impedance mismatch you'll either get less power from the amp or short circuit the amp. If you know these I can help you come up with the best solution.
If you know bridging is the best option, then you'll have to know which terminals on the amp to use in order to bridge. This is how it normally works. On a 2 channel amp...you would normally take the positive from one channel to the positive on the speaker, and the negative from the OTHER channel to the negative on the speaker...and this is how you bridge the amp. The other two channels would remain UNCONNECTED. BUT!!! you have to make sure you use the correct 2 channels...it varies from manufacturer. But take heed not overload the amp...and not to overpower the sub. There are a few different ways that you can configure the subs if you find it beneficial to bridge your amp, these would take long to explain and would depend on the impedance of your subs and specs of your amp...these wiring configurations is how you match the impedance of the speakers input to the amps output (and is very important to do correctly) Look up "parallel and series" wiring configurations. Let me know if this helps, or if you need further help. Find out the impedance of your subs and the specs of your amp and i'll be able to assist you more. Hope this helps.
Mar 27, 2008 | Car Audio & Video
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Hai Im new here recently i just took out my player Power acoustik PTID8400.... when i install it back nothing happen... the power is on but the monitor refuse to come out... how to fix this problem......
sorry had no luck with a manual online for your exact model http://www.poweracoustik.com or contact them direct Power Acoustik Electronics 1550 S. Maple Ave. Montebello, CA 90640 USA Phone: 323-722-3333 Fax: 323-722-1122 International Sales: alex@poweracoustik.com USA dealer contact: don@poweracoustik.com Tech service: Tech-support@poweracoustik.com All other inquiries: info@poweracoustik.com Hope this helps :)
Mar 16, 2007 | Power Acoustik PTID8400 Car DVD Player
Car Audio & Video Logo
67 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
